    [Plugin] Face Flattener 0.19
    50 Posts 29 Posters 57.0k Views 29 Watching
      Here's a sample of such a loop. I just moved the vertex of the connecting line onto the outer edge. There are other cases when this happen as well.
      If you try to delete any of the edges of the internal face you'll also delete the outer face.
      Crossloop.skp
      • utilerU Offline
        utiler
        For some reason, I don't get this script....
        Does it work similar to "drop.rb"?
        cheers,
        Just Curious...
          Whooopdedoo! This is fixed in 7.1!!!
            mnaylor375
            Zach, you're my hero! Thanks.
            • G Offline
              Glidias
              The script doesn't work and has no effect. Any reason why??
                No. You must provide some more info. Exactly what doesn't work? No menus? No action when you activate the menus? Not the desired results? What did you do when you tried to use it? (detailed) If you open the Ruby Console, did you get any error messages when you tried to activate it?
                  JPMays
                  I also get no results. According to the OP, I should select my object(s), then context click and select "Flattening Script", then select the plane I wish to flatten to. Nothing happens when I do this, however.
                  Hofstadter's Law: It always takes longer than you expect, even when you take into account Hofstadter's Law.
                    D_FAST
                    as mentioned, does not work as described. Running v8 pro
                      Can you elaborate more? "Does not work" doesn't really say a whole lot.
                      So you get errors? Does it not work as expected - if so what was the result and what was expected?
                      • robertWanR Offline
                        robertWan
                        Why not working?
                        SU8
                        Maybe there is another plugin? Artisan is paid 😞
                        http://www.screencast.com/t/20sxZ3Uuk
                        Robert
                        • 3 / 3
