    Silvershadow's eye candy 1: The river runs thru it
    125 Posts 62 Posters 69.8k Views 62 Watching
      Click Draw
      Hey Silver....your extremely talented. Do you use SU in your daily work?
      Jeff
      Have I mentioned how much of a laugh I get out of some of the Signatures on here!
        silver_shadow
        hi there, thanx for the comment, i only use sketchup. My profession is to build models for an architectural firm all day 😄 quite nice
        been using sketchup for 3 years. My primary render engine i use is mainly Vray for sketchup, been using that for a year an a half
          Camille
          hye !!
          I'm a young french user and I don't understand all wich write on this page but I'm really really impressed !
          this render is amazing, very very good !
          When I'll be able to do 1/4 of that I'll be happy !!
          very nice !
          Camille
            akololo
            great job!!!!
            by the way, im still confused how to make the background...like the mountain... how did u make it?.
            hehe
            thanks... and job well done!
              silver_shadow
              like the old fashioned way. Create a alpha of your render, or just cut out the background via photoshop.
              so you will have a model which has no background. Then just put a mountain image in behind the model.
                skyscraper100
                OMG!!!!! this is AWESOME!! 😮
                btw what software?
                The way you think Creates reality for yourself.
                  silver_shadow
                  hit there
                  All the candy series was an experiment to see how far i can push sketchup untill it folds
                  So to be true to the program, i had to use only sketchup for modelling. The first candy was not really intended to be rendered, but eventually got rendered in vray and a little bit of photoshop. The candy 2 model went the same path, all 100% sketchup, no elements were build in another program and then brought back, because then it would have defeated the purpose. Renderd in maxwell, vray, and fryrender.
                  2008 i will start my last candy, trying to push sketchup for one last time, building everything in sketchup again. I hope it will be bigger and better and at least ten times more intense than candy 2. But we all have to wait and see 😉
                    Andrija Posarić
                    Silver, I am really amazed with your work. The final product looks fantastic, and I like the atmosphere in the scene.I see that you utilized a lot of rubies:-) I haven't heard for half of them but, I see they are very useful.
                    Keep up the inspiring work, I haven't seen work of such quality for a long time here.
                    Cheers,
                    Andrija
                    Cheers, Andrija
                      I doubt he will 😉
                      • W Offline
                        wheay
                        very nice work! and tutorials.. thanks for sharing it to all. keep it up. 😍
                        "i try to learn everyday"
                        http://designerslandmark.blogspot.com/
                          silver_shadow
                          Hi Coen
                          hee hee i think we all just have to wait and see whats its gonna be. sorry guys
                          The thing about last time, it will definately not be my last model, its just doing these candy models is actually a real hard process, saving each day as a seperate file as you progress and try to document youre every move, where the normal way is just, build the model, and post it. But again, ive learned this is ACTUALLY the proper way to demonstrate youre model, so yea, i would not say it will be part of candy, but probably more similar stuff.
                          • romboutR Offline
                            rombout
                            @jim said:
                            @solo said:
                            I cannot seem to locate it but I once remember talk about a 'Greeble' script, my thinking was that this too could be a solution.
                            However Silver you certainly used SP in a very creative way.
                            It's not well documemented, but protrude can offset, protrude, and taper faces. Leave the second column blank unless you want a random number btween the range.
                            [attachment=1:1pvfn6zh]<!-- ia1 -->protrude.jpg<!-- ia1 -->[/attachment:1pvfn6zh]
                            This model was produced using these inputs:
                            [attachment=0:1pvfn6zh]<!-- ia0 -->Clipboard01.jpg<!-- ia0 -->[/attachment:1pvfn6zh]
                            hi jim, im workin on a mac and it seems it doesnt work for me... any help possible???
                              Jim
                              No word yet.
                              I hope to be able to get back to working on Protrude before the end of March.
                              • E Offline
                                EDMON242004
                                hello silvsershadow, since i saw ur work done in sketchup i cant believe those can really be done using su, now i will be using it for all my projs, hope to see more of your tutorials, specially w/ window glass effects, thanks
                                • P Offline
                                  prismcnd
                                  OMG!!! I'm in sheer shock and amazement,absolutely breathtaking. DO NOT STOP! You are an inspiration to all
                                  “Whatever the mind of man can conceive and believe, it can achieve.” -W.Clement Stone (American best selling Author and Founder of Combined Insurance Co (now a part of Aon Corp.), 1902-2002)
                                  • Chris FullmerC Offline
                                    Don't miss his eye candy 2 thread:
                                    http://forums.sketchucation.com/viewtopic.php?f=81&t=12513&st=0&sk=t&sd=a
                                    Chris
                                    All my Plugins I've written
                                    • P Offline
                                      publied
                                      what's saying? you master! thank you for this very interesting tutorial.
                                      (is true you used 4 days only for all this works?)
                                      ciao.
                                      /paolo
                                      hire me@ http://www.publied.it !
                                        silver_shadow
                                        Hi there, no it took me about 4 days to render my scene in parts during the day.
                                        The modelling process took about a month if i could remember correctly.
                                        • simon le bonS Offline
                                          simon le bon
                                          HeyHey! SilverShadow:
                                          The ghost returns....
                                          Hi all young and old sketchup users, developers of the new sketchup 7 team,and any other modeler out there that do not really know the true potential power of this amazing tool. Today i want to share the power of sketchup itself, to encourage those who thinks sketchup is just a tool that can only build block models and nothing more.
                                          For my part your intention have simply found the center of the target!! Never thought it was possible to do so real with SU. And also a dreaming beautiful scene.
                                          I have to come back again and again to study your tuts. Bravo et un grand merci pour votre générosité!!
                                          *simon
                                            Latetzki
                                            Amazing work. What's the render plugin you used? V-ray?
                                            • 6
                                            • 7
                                            • 6 / 7
