Numerous objects
If I have numerous object in a scene
Does exist something for exclude some of them for they are not calculated by SketchyPhysics2?
Hide ? Lock? ... -
I think if you right click the object->sketchy physics properties (or something similar)->ignore it will leave the objects out of the simulation.
EDIT: right click->state->ignore
If I have a thousand copy of an object : One normal, 999 ignored
Yes for the effect but how to be sure that is not 1000 tests inside the plug?So waiting the creator answer
I would have thought the entire point in an ignore button would be to make sure the object isnt usec by the physics engine, i cant think what else it would do.
Using Ignore should not be slow. It just one little check when you first press play.
Thx for the precision
