    Numerous objects
    6 Posts 3 Posters 1.3k Views 3 Watching
      If I have numerous object in a scene
      Does exist something for exclude some of them for they are not calculated by SketchyPhysics2?
      Hide ? Lock? ...
        remus
        I think if you right click the object->sketchy physics properties (or something similar)->ignore it will leave the objects out of the simulation.
        EDIT: right click->state->ignore
          If I have a thousand copy of an object : One normal, 999 ignored
          Yes for the effect but how to be sure that is not 1000 tests inside the plug?
          So waiting the creator answer πŸ˜„
            remus
            I would have thought the entire point in an ignore button would be to make sure the object isnt usec by the physics engine, i cant think what else it would do.
              CPhillips
              Using Ignore should not be slow. It just one little check when you first press play.
                Thx for the precision 😎
