    Almost Only SketchUp
    7 Posts 4 Posters 1.0k Views 4 Watching
      rcossoli
      Today I show them some pictures before being rendered in kerkythea asusual.
      Some projects are completed but I think were good so is that the show, feel free to comment.
      The English is courtesy of the "English translator" of google jajajaja
      http://img354.imageshack.us/img354/8355/ayresdelparquepiso6tw5.th.jpg
      http://img354.imageshack.us/img354/7035/cocinacomedormo6.th.jpg
      http://img374.imageshack.us/img374/8101/loft1rk3.th.jpg
      http://img374.imageshack.us/img374/1939/pelegriniil3.th.jpg
      THREEDIMENSIONSWEB dot COM
      • W Offline
        watkins
        Dear Ricardo,
        Can you tell the forum something about the project? For example, are you designing for a client?
        The layout of the living space is interesting (very open and friendly), but occasionally people like privacy so a recessed curtain to screen the bed from the kitchen might be nice.
        There would appear to be a large, unused volume under the platform bedroom/bed. Could that be used for storage? The stairs could also be used for storage by constructing the stairs so under each tread there is a pull-out draw (like a large, staggered chest of draws).
        Designers always forget about storage, which is very important when planning compact accommodation.
        Kind regards,
        Bob
        • plot-parisP Offline
          plot-paris
          I really like the designs - especially the second and third one.
          looking forward to see the renders... πŸŽ‰
            rcossoli
            thanks for the comments.
            watkins 1 and last image if they are to customers but the study where I work, the other two are only ralizaciones practice I made of pure pleasure.
            you're right as storage, the pensare, thanks.
            plot-Paris: the renders will also take some time as some but you can see on my blog that appears in my signature, we see you.
            • DanielD Offline
              Daniel
              Looking good, Ricardo.
              A few comments on the second image:
              Your stringer is following both the treads and the risers as it goes up the wall, until you get to the top riser. For consistency, I would think you'd want to run it up that riser and tie it into the base board in the bedroom.
              Judging by the stools, the counter doubles as an eating surfaces, bujt it doesn't appear the counter projects out in that area, which means someone sitting on the stools would have to lean too far forward.
              Finally, you should add at least a wall-mounted handrail to those stairs, for safety's sake (even if your local codes don't dictate it). In the US I am unaware of any code that wouldn't require both a handrail and a guardrail.
              My avatar is an anachronism.
                rcossoli
                daniel thanks for the suggestion techniques, greetings
                  rcossoli
                  here there are 3 of 4 images that began earlier, these are rendered in Kerkythea, the image of the loft, the third, or maybe can not find the delete jajaja, greetings
                  http://img529.imageshack.us/img529/1022/98008200vt5.th.jpg
                  http://img341.imageshack.us/img341/9527/interiorterminado2chicakb1.th.jpg
                  http://img517.imageshack.us/img517/3228/15edificiofrente1kd6.th.jpg
