    SketchUp-Ruby Resources
    29 Posts 16 Posters 128.9k Views 16 Watching
    • J
      Jim
      Official Google Sketchup API Documentation
      • SketchUp API Blog
      • Google SketchUp API Home (Google Code)
      • Google SketchUp Developers Group (Google Groups)
      • Google SketchUp API Documentation (Reference)
      Ruby Operator Precedence
      The reserved words and, or and not have a lower precedence than &&, || and !. The tricky part is that their precedence is lower than the assignment operator = .
      a = false or true evalualtes to ( a = false) or true.
      You probably meant one of:
      a = (false or true)
      a = false || true
      Avoid using the typename method
      In this discussion, user AlexMozg presents evidence that avoiding the object.typename can give your script a considerable performance increase.
      Instead, use object.is_a? Class::Type.
      He also says in a model that is less than 10 MB, there may not be a substantial increase, but for very large models the speed increase is considerable.
      Installing Extensions
      • How to find the Plugins folder?
        Here's a method that tells you right where your version of SketchUp is looking for extensions. Copy and paste the code into the Window > Ruby Console dialog, and press ENTER. It works for all versions of SketchUp, and on all operating systems, too.
      Sketchup.find_support_file("Plugins")
      http://www.sketchucation.com/forums/scf/download/file.php?id=22479
      And in my case the location to install plugins is C:/Program Files/Google/Google SketchUp 7/Plugins
      Links to important and notable Dev Forum posts past and present. Let me know if there is a topic that should be included here.
      • Building Ruby C Extensions compatible with SketchUp
      • Set.insert vs array << x unless array.include?(x)
      • How to enable thumbnail preview (windows)
      • Google SketchUp Ruby API - What's New in SketchUp 7.1
      • WebDialogs - The Lost Manual -- thomthom (Nov 2009)
      • Report Ruby Bugs and Documentation issues in this thread. The SketchUp developers are aware of, and read it.
      • [Code] Real UV from UVHelper data - thomthom (Oct 2009)
      • State of Observers — 19 July 2009
      • [Code] UnicodeEx - Sketchup + Character Encoding (thomthom)
      • [url=http://forums.sketchucation.com/viewtopic.php?f=180&t=13666:3tvu9trw]SketchUp RUBY API Wishlist (way of coding wishes, please)[/url:3tvu9trw]
      • WebDialogs: [url=http://forums.sketchucation.com/viewtopic.php?f=180&t=22491:3tvu9trw]How to Hide the Scrollbars[/url:3tvu9trw]
      • [url=http://forums.sketchucation.com/viewtopic.php?f=180&t=10142:3tvu9trw]SketchUp-Ruby Resources[/url:3tvu9trw]
      • [url=http://forums.sketchucation.com/viewtopic.php?f=180&t=16909:3tvu9trw]Must Have Ruby Plugins - Visual Index[/url:3tvu9trw]
      • [url=http://forums.sketchucation.com/viewtopic.php?f=180&t=16792:3tvu9trw]< SCF Toolbars Authors >[/url:3tvu9trw]
      • [url=http://forums.sketchucation.com/viewtopic.php?f=180&t=16164:3tvu9trw]Collaborative Effort - Ruby Template, RDoc, and Localization[/url:3tvu9trw]
      • [url=http://forums.sketchucation.com/viewtopic.php?f=180&t=12423:3tvu9trw]Word of warning to developers[/url:3tvu9trw]
      • [url=http://forums.sketchucation.com/search.php?keywords=code&terms=all&author=&fid=180&sc=1&sf=titleonly&sr=topics&sk=t&sd=d&st=0&ch=300&t=0&submit=Search:3tvu9trw]Ruby Forum Code Search[/url:3tvu9trw]
      SketchUp & Ruby Development Discussions
      • Rick's [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=12423:3tvu9trw]Words of Warning[/url:3tvu9trw] - Important points to remember for writing plugins.
      • [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=8997&start=0&st=0&sk=t&sd=a:3tvu9trw]How do you make plug-ins for sketchup[/url:3tvu9trw]
      • [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=6818:3tvu9trw]What is needed to script?[/url:3tvu9trw]
      • [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=4796:3tvu9trw]ruby dev environment[/url:3tvu9trw]
      • [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11160:3tvu9trw]Creating an API[/url:3tvu9trw]
      • [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=12633:3tvu9trw]$ versus @[/url:3tvu9trw]
      • [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=14608:3tvu9trw]Manipulating the InputPoint[/url:3tvu9trw]
      Ruby Editor Suggestions
      • [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13206:3tvu9trw]ConTEXT[/url:3tvu9trw] Editor w/Ruby Highlighting
      • [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=169&t=6903:3tvu9trw]Notepad++[/url:3tvu9trw] editor
      • Notepad++ AutoComplete files
        • by [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=15875&p=123500:3tvu9trw]Didier Bur[/url:3tvu9trw]
        • by [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=4796&p=25556#p111076:3tvu9trw]radhikari[/url:3tvu9trw]
      • [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13574&p=101153#p101153:3tvu9trw]EditPlus[/url:3tvu9trw] editor
      • RDE
      Ruby Challenges
      1. [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=2107:3tvu9trw]UI.play_sound jukebox[/url:3tvu9trw] (RickW)
      2. [url=http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13715:3tvu9trw]best fitting bounding box[/url:3tvu9trw] (Matt)
      Ruby Docs
      • [url=http://ruby-doc.org/:3tvu9trw]Ruby-doc.org[/url:3tvu9trw]
      • [url=http://www.ruby-doc.org/core/classes/Array.html:3tvu9trw]Arrays[/url:3tvu9trw]
      • [url=http://www.ruby-doc.org/core/classes/String.html:3tvu9trw]Strings[/url:3tvu9trw]
      • [url=http://www.ruby-doc.org/core/classes/Hash.html:3tvu9trw]Hashes[/url:3tvu9trw]
      • [url=http://www.ruby-doc.org/core/classes/Enumerable.html:3tvu9trw]Enumerable (module)[/url:3tvu9trw]
      • [url=http://www.ruby-doc.org/core/classes/IO.html:3tvu9trw]IO[/url:3tvu9trw]
      • [url=http://www.ruby-doc.org/core/classes/Time.html:3tvu9trw]Time[/url:3tvu9trw]
      Ruby Books
      • [url=http://www.autosketchup.com/:3tvu9trw]Automatic Sketchup[/url:3tvu9trw]
      • [url=http://rubybestpractices.com/:3tvu9trw]Ruby Best Practices[/url:3tvu9trw]
      • [url=http://www.sapphiresteel.com/The-Book-Of-Ruby:3tvu9trw]The Book of Ruby[/url:3tvu9trw]
      Extension Collections
      • [url=http://www.smustard.com/:3tvu9trw]Smustard(TM) - the Companion to Sketchup(TM)[/url:3tvu9trw]
      • [url=http://www.crai.archi.fr/RubyLibraryDepot/Ruby/RUBY_Library_Depot.htm:3tvu9trw]Ruby Library Depot[/url:3tvu9trw] Here are the contributions of the Ruby developers of the SketchUp community since 2004.
      • [url=http://www.pixero.com/:3tvu9trw]Jan Sandström[/url:3tvu9trw] (Pixero)
      • [url=http://www.tensile-structures.de/index.html:3tvu9trw]Soap Skin & Bubble[/url:3tvu9trw]
      • [url=http://errorinitus.de:3tvu9trw]Mario Pehle[/url:3tvu9trw] (azuby) under Software
      • [url=http://www.accustudio.com/index.php?option=com_remository&Itemid=88&func=select&id=23:3tvu9trw]Accustudio File Repository[/url:3tvu9trw] - appears to mirror the Ruby Library Depot.
      • [url=http://sketchuptips.blogspot.com/:3tvu9trw]SketchUp Plugins Blog[/url:3tvu9trw]
      Resources
      • [url=http://forums.sketchucation.com/viewtopic.php?f=180&t=26352:3tvu9trw]Ruby Scrambler Download[/url:3tvu9trw]
      • H
        Heven7_floor
        Great Jim
        Your suggestion is usefully to every newer like me .
        Thanks 🎉
        • W
          watkins
          Dear Jim,
          Many thanks for all your hard work. It is greatly appreciated.
          Kind regards,
          Bob
          • S
            sepo
            Just found this depository of Plugins for SU. There a lot of known ones but nevertheless mayby useful.
            • O
              Oaht
              Thanks for your effort. Cheers 👍
              • V
                vashstamp3de
                I hope this helps...(and not violating someone 😞 )
                The page is not found
                (xoomer.virgilio.it)
                Good Luck!
                • R
                  remus
                  I imagine a link to contact each plugins developer would be appreciated by the authors 👍
                  • P
                    Pauline01
                    thx again it's very very nice!
                    • A
                      Align
                      thanx for this awesome thread! i give it a 10
                      • thomthomT
                        Jim, maybe include the path to install plugins on Mac as well. That one seem to be the most confusing amongst users it seems.
                        • R
                          RickW
                          http://xoomer.virgilio.it/kites/programmi/grafica/sketcplugins.html
                          Good Luck!
                          Just point the Windowizer link to Smustard, please. It currently points to a broken link on RLD.
                          RickW
                          www.smustard.com
                          • thomthomT
                            Might be worth noting that definition names can't be trusted to be unique: http://forums.sketchucation.com/viewtopic.php?f=11&t=28094
                            • thomthomT
                              Very nice list Dan!
                              @dan rathbun said:
                              Ruby Best Practices, by Gregory T. Brown
                              ** PDF
                              http://sandal.github.com/rbp-book/pdfs/rbp_1-0.pdf
                              This one looks very interesting.
                              • Dan RathbunD
                                Dan Rathbun
                                @thomthom said:
                                Very nice list Dan!
                                Thanks.. (but I didn't find all these myself.) I had it posted over at GG, but it kept getting farther down the topic stack. Over here I know right where it is, and can format it.
                                Jim found that one.
                                P.S. - @Jim your free to cut and paste anything from here to the top of the thread.
                                I'm not here much anymore.
                                • Dan RathbunD
                                  Dan Rathbun
                                  UPDATES / ADDITIONS (in this topic.)
                                  Ruby Interpreter DLLs (Win32)
                                  Edited Instructions to be more clear and precise.
                                  Added DLL for:
                                  • latest Ruby v 1.8.7 p330
                                  RUBY PROGRAMMING REFERENCES - CHM format
                                  Added CHMs for:
                                  • latest Ruby v 1.8.7 p330* latest Ruby v 1.9.2 p136
                                  • J
                                    Jim
                                    This site has many videos of Ruby talks recorded at various Ruby Conferences - http://confreaks.net
                                    Some good stuff there - if you can find them...
                                    • R
                                      rricon
                                      Hello,
                                      Where to find the .h file of msvcrt-ruby18.dll file ?
                                      Regards,
                                      • Dan RathbunD
                                        Dan Rathbun
                                        In the source:
                                        ftp;//ftp.ruby-lang.org/pub/ruby/1.8/ruby-1.8.6-p287.zip
                                        • Dan RathbunD
                                          Dan Rathbun
                                          book: "Programming Ruby - The Pragmatic Programmer's Guide"
                                          Copyright © 2000 Addison Wesley Longman, Inc.
                                          ProgrammingRuby.zip
                                          Released under the terms of the Open Publication License V1.0.
                                          • T
                                            todd burch
                                            Chunky Bacon. I didn't see a link for Why's Poignant Guide to Ruby. A true classic.
                                            http://mislav.uniqpath.com/poignant-guide/book/chapter-1.html
                                            • 1 / 2
