    TIN sphere
    7 Posts 2 Posters 1.5k Views 2 Watching
    • P
      pav_3j
      inspiration from freds constant tinkering, a TIN sphere.
      easy to make, and quite satisfying too!
      not sure quite how useful this is after the implementation of FFD and SubSmooth, but here it is anyway!
      you can get some nice effects using the smoove tool.
      Pav
      TIN sphere.skp
      Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
      • R
        remus
        If you dont mind me asking, howd you make this?
        • P
          pav_3j
          i can make a quick tut if you want?
          pav
          • R
            remus
            Thatd be cool, thanks.
            • P
              pav_3j
              Here you go.
              it's a very quick one as i am at work, i shall do a more detailed one when i get time.
              also, the last few scenes do not have TIN squares on, just filled geometry to save time..
              any probs, give me a shout
              pav
              TIN sphere Tut.skp
              • R
                remus
                Cheers for the tut, but ifim allowed could i suggest another method?
                its kind of cheating, but if you start making a sphere as you normally would, but select the 2 circles (before oyu use follow me) right click->explode to curve. If you then keep making the sphere as normal.
                Once youve done that, and cleaned everything up, just select the faceted sphere and use the subd tool. Probably a bit faster than the TIN thing...
                • P
                  pav_3j
                  ah yeah, hadn't thought of that!
                  tips galore!
                  pav
