    Geomatry Resizer or Paramatric???
    43 Posts 14 Posters 7.7k Views 14 Watching
    • OscarLokO Offline
      OscarLok
      Here is the rough demo :-
      http://www.youtube.com/watch?v=c-OYXKwg2WY
      In the AVI, I draw trapezoid (The word trapezoid has multiple definitions. Here is to describe a four-sided polygon, with two edges parallel and the other two equal in length.) and then change it into triangle .
      In the demo, it show the "Both Side A & B" Adjust, that means no lock to both side (as I describe previus reply). It show the one side locked or the other side adjusted, too. We can choose which side to lock or adjust.
      Oscar
      [b:dhgwcjdo][color=#0080BF:dhgwcjdo]JAYA Design & Renovation Sdn. Bhd.[/color:dhgwcjdo][/b:dhgwcjdo] [b:dhgwcjdo][color=#00BF40:dhgwcjdo]T[/color:dhgwcjdo][color=#00BC42:dhgwcjdo]h[/color:dhgwcjdo][color=#00B843:dhgwcjdo]e[/color:dhgwcjdo] [color=#00B247:dhgwcjdo]e[/color:dhgwcjdo][color=#00AE48:dhgwcjdo]x[/color:dhgwcjdo][color=#00AB4A:dhgwcjdo]p[/color:dhgwcjdo][color=#00A84C:dhgwcjdo]e[/color:dhgwcjdo][color=#00A44D:dhgwcjdo]r[/color:dhgwcjdo][color=#00A14F:dhgwcjdo]t[/color:dhgwcjdo] [color=#009A53:dhgwcjdo]i[/color:dhgwcjdo][color=#009754:dhgwcjdo]n[/color:dhgwcjdo] [color=#009058:dhgwcjdo]c[/color:dhgwcjdo][color=#008D59:dhgwcjdo]u[/color:dhgwcjdo][color=#008A5B:dhgwcjdo]s[/color:dhgwcjdo][color=#00865D:dhgwcjdo]t[/color:dhgwcjdo][color=#00835E:dhgwcjdo]o[/color:dhgwcjdo][color=#008060:dhgwcjdo]m[/color:dhgwcjdo][color=#007C62:dhgwcjdo]i[/color:dhgwcjdo][color=#007963:dhgwcjdo]z[/color:dhgwcjdo][color=#007565:dhgwcjdo]e[/color:dhgwcjdo][color=#007267:dhgwcjdo]d[/color:dhgwcjdo] [color=#006B6A:dhgwcjdo]o[/color:dhgwcjdo][color=#00686C:dhgwcjdo]f[/color:dhgwcjdo][color=#00656D:dhgwcjdo]f[/color:dhgwcjdo][color=#00616F:dhgwcjdo]i[/color:dhgwcjdo][color=#005E71:dhgwcjdo]c[/color:dhgwcjdo][color=#005B73:dhgwcjdo]e[/color:dhgwcjdo] [color=#005476:dhgwcjdo]s[/color:dhgwcjdo][color=#005178:dhgwcjdo]y[/color:dhgwcjdo][color=#004D79:dhgwcjdo]s[/color:dhgwcjdo][color=#004A7B:dhgwcjdo]t[/color:dhgwcjdo][color=#00477D:dhgwcjdo]e[/color:dhgwcjdo][color=#00437E:dhgwcjdo]m[/color:dhgwcjdo][color=#004080:dhgwcjdo].[/color:dhgwcjdo][/b:dhgwcjdo]
      • BepB Offline
        Bep
        Hi Oscar,
        At last!
        I am very glad that you are taking a real effort in making a Plug-in or ruby that could
        Make Surveying with trilateration possible.
        My big-wish for a tool like that is very old.
        See http://groups.google.com/group/Ruby-API/browse_thread/thread/9a853979f28f4c46/dab01f684101c6e4?lnk=gst&q=bep+van+Malde#dab01f684101c6e4
        From these links please try out the Mobile cad Demo to get inspired.
        See also my request from last week. http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=9718
        The Sketchright program is not available anymore but is as a good example ,so I will try to PM you , to find a way for you to explore the program.
        (I am glowing from anticipation .)
        Oscar you are one of the Ruby hero’s.
        Greetings Bep van Malde
        "History is written by the winners"
        • OscarLokO Offline
          OscarLok
          Hi Bep,
          The MobileCAD is only in German. Do you have any video tutorial regarding its' U.I. and the process of drawing a floor plan, please? (I would like to try to understand it by visually.)
          Let me see weather there are orther way to make trilateration possible.
          What I understand is to lock two edges' length and adjust the third edge's length. I may be wrong. πŸ˜•
          Oscar
          • BepB Offline
            Bep
            Hallo Oscar,
            I to have only the German Demo version.
            One of the great advantages of the Mobilecad program for trilateration is that it triangulates the sketch of the floor-plan for you, and you can toggle trough the different triangulation options until you find the one that is right to you.
            Although I think you should also be able to triangulate it yourself.
            Than you just fill in the real size of every (blue) line, the colour chances afterwards to indicate that it has been scaled to the right size and it automatically locks this line-length.
            The program scales the floor plan after every input, so you are visually warned if you fill in a really wrong dimension.
            One of the key words in this process is over- and under-constraint warning.
            Ill try to explain that as far is I think to now : for example a four sided figure from which only the four sides are known can not be drawn and is called under-constraint ,whereby as one diagonal is also known it can correctly be constructed, but when you try to incorporate the second diagonal in the drawing the figure is called over-constrained meaning that mathematically there will always some sort of rounding (or there has been made a small measuring error ) difference, the math solver will normally not allow that, and so a over-constraint warning will pop up.
            Please look at the video
            http://nl.youtube.com/watch?v=2zHtGCoki3c
            (excuse me for the bad image =first time)
            By the way I am doing a posting about a little bit similar issue at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=9718
            Bep
            • OscarLokO Offline
              OscarLok
              Thanks ! Bep !
              You give me a lot of imformation ! Let me see what I can do.
              I have start it.
              Oscar
              any suggestion are welcome ! πŸ˜„
              • BepB Offline
                Bep
                Hello Oscar,
                I forgot to mention that if possible,you should be able to exclude a part of a face from triangulation (this is not possible in mobilecad ,and thats the reason I cant use it)
                Greetings, Bep
                part excluded from triangulation.skp
                • OscarLokO Offline
                  OscarLok
                  Hi Bep, a4chitect & Gjenio
                  There is a new 2D parametric geometry avi which lock the edges in the first POST . It show that how to make the trilateration. We start to do it by select a face, then we can lock the edge we want.
                  By the way, we can adjust (or lock) which side(or both sides) to be adjusted.
                  This is just a quick test. Don't know is it the correct way.
                  If it is the right way, I will develope it further ! πŸ˜’
                  Oscar
                  • OscarLokO Offline
                    OscarLok
                    Hi Bep,
                    May I know that do you receive my PM, please?
                    Oscar
                    • jujuJ Offline
                      juju
                      Hi Bep,
                      Oscar
                      Check you "outbox" in the User Control Panel (UCP), if the PM is no longer in your "outbox" the recipient has opened/received it.
                      • OscarLokO Offline
                        OscarLok
                        Hi Juju
                        There are 3 PM in the "outbox" . May I know how to resend again, please?
                        Regards
                        Oscar
                        • jujuJ Offline
                          juju
                          You can't resend them, they've already been sent, the recipients have not looked at them yet, that is what it means when PM's remain in the "outbox".
                          • FletchF Offline
                            Fletch
                            Hi Oscar,
                            Here's the original thread where this topic was discussed. I realize what I'm referring to in that thread is possibly a bit more involved than what you're trying to do... perhaps not.
                            but my idea outlined here will make someone some money if they set the right price.
                            I know someone wrote a script to do this (Gaeius linked me to it), but they wanted a thousand dollars for it or more... and what they need to ask is a reasonable price for it... like $80 or something... then perhaps everyone could actually use it... giving it an elitist price only stifles development - IMHO.
                            I really think your script has a lot of potential.
                            Is there a way you could make the selection of points or faces to lock into a graphically interactive tool instead of the awkward pull-down menu? (like how it works with the Subdivide and Smooth tool)
                            Fletch
                            3D Modeling addict. Former owner/developer of Twilight Render. sleepinggiantvisual.com
                            • BepB Offline
                              Bep
                              Hi Bep,
                              Oscar
                              Hi oscar,
                              As already posted to you in your PM-box, I instaled your test script succesfuly.
                              You should however have warned me about how great this script is.
                              I needed half an hour to get myself under control again.
                              Now my enthousiasme is somehow under control,I can give you some first, hopefully usefull remarks.
                              -Could you script preferbly use the users own units settings (my settings are Decimal, and cm for example.
                              -Could the defauld box to fill in when you want to adjust a line lenght be the size box.
                              (The most important for trilateration)
                              -If the first dimension of the sketcht triangle is changed, the hole figure should be scaled without losing the proportions of the initial sketch,like when scaling with the "tape measure"tool.
                              -The warning if you make size off a side of a triangle to large ,now is "the minimum size=..",
                              should it not be "max.size="?
                              Now I am going to take a beer and play around with your skript for a while.
                              If some other remarks come up I will post them tomorow.
                              Greetings,
                              Bep van Malde
                              • philemP Offline
                                philem
                                I have been following this thread basically since it started, and am very interested in this ruby.
                                Have I missed the release of it for downloading or is it still under development?
                                thanks
                                Just do it, it might be fun.
                                • OscarLokO Offline
                                  OscarLok
                                  Hi Bep,
                                  *units setting should be no problem.
                                  *proportions of the initial sketch can be figure out.
                                  *"max.size=" will be done.
                                  *Only I do not understand is :- 😳
                                  Thanks for your feedback πŸ˜„
                                  Oscar
                                  Any feedback is welcome!
                                  • OscarLokO Offline
                                    OscarLok
                                    O I see! β˜€
                                    Thank you! Juju
                                    Oscar
                                    • BepB Offline
                                      Bep
                                      Hi Oscar,
                                      I just lookt at you post,and saw your question.
                                      I attacht a picture to make clear what i mean.
                                      greetings Bep
                                      defauld box to fil in when you wont to edit a line lenght
                                      • OscarLokO Offline
                                        OscarLok
                                        May I have a copy of the Building's program spreadsheet excel file, please ? (You can PM to me if you want.)
                                        Oscar
                                        • OscarLokO Offline
                                          OscarLok
                                          Hi Fletch,
                                          I have send you a PM to test.
                                          Any feedback are welcome! πŸ˜„
                                          Regards
                                          Oscar
                                          • OscarLokO Offline
                                            OscarLok
                                            Hi Fletch,
                                            As we agree with this :-
                                            @fletch said:
                                            Really awesome, Oscar, yes, let's post this to the whole forum for all to share ideas. I would love a custom answer for the way our firm handles the excel spreadsheet program, but really probably it's best for everyone if it's more universal... as I mentioned.
                                            but the fact you can read a spreadsheet from excel and draw spaces - that's really what I was looking to find out - and you did it! 😍
                                            Now, I have a format of it. Any feedback are welcome! I will do a quick script(spreadsheet to SU) for it.
                                            Regards
                                            Oscar
                                            Universal Format.xls
                                            • 2 / 3
