    Geomatry Resizer or Paramatric???
    43 Posts 14 Posters 7.2k Views 14 Watching
    • BepB Offline
      Bep
      Hallo Oscar,
      I to have only the German Demo version.
      One of the great advantages of the Mobilecad program for trilateration is that it triangulates the sketch of the floor-plan for you, and you can toggle trough the different triangulation options until you find the one that is right to you.
      Although I think you should also be able to triangulate it yourself.
      Than you just fill in the real size of every (blue) line, the colour chances afterwards to indicate that it has been scaled to the right size and it automatically locks this line-length.
      The program scales the floor plan after every input, so you are visually warned if you fill in a really wrong dimension.
      One of the key words in this process is over- and under-constraint warning.
      Ill try to explain that as far is I think to now : for example a four sided figure from which only the four sides are known can not be drawn and is called under-constraint ,whereby as one diagonal is also known it can correctly be constructed, but when you try to incorporate the second diagonal in the drawing the figure is called over-constrained meaning that mathematically there will always some sort of rounding (or there has been made a small measuring error ) difference, the math solver will normally not allow that, and so a over-constraint warning will pop up.
      Please look at the video
      http://nl.youtube.com/watch?v=2zHtGCoki3c
      (excuse me for the bad image =first time)
      By the way I am doing a posting about a little bit similar issue at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=9718
      Bep
      "History is written by the winners"
      • OscarLokO Offline
        OscarLok
        Thanks ! Bep !
        You give me a lot of imformation ! Let me see what I can do.
        I have start it.
        Oscar
        any suggestion are welcome ! ๐Ÿ˜„
        [b:dhgwcjdo][color=#0080BF:dhgwcjdo]JAYA Design & Renovation Sdn. Bhd.[/color:dhgwcjdo][/b:dhgwcjdo] [b:dhgwcjdo][color=#00BF40:dhgwcjdo]T[/color:dhgwcjdo][color=#00BC42:dhgwcjdo]h[/color:dhgwcjdo][color=#00B843:dhgwcjdo]e[/color:dhgwcjdo] [color=#00B247:dhgwcjdo]e[/color:dhgwcjdo][color=#00AE48:dhgwcjdo]x[/color:dhgwcjdo][color=#00AB4A:dhgwcjdo]p[/color:dhgwcjdo][color=#00A84C:dhgwcjdo]e[/color:dhgwcjdo][color=#00A44D:dhgwcjdo]r[/color:dhgwcjdo][color=#00A14F:dhgwcjdo]t[/color:dhgwcjdo] [color=#009A53:dhgwcjdo]i[/color:dhgwcjdo][color=#009754:dhgwcjdo]n[/color:dhgwcjdo] [color=#009058:dhgwcjdo]c[/color:dhgwcjdo][color=#008D59:dhgwcjdo]u[/color:dhgwcjdo][color=#008A5B:dhgwcjdo]s[/color:dhgwcjdo][color=#00865D:dhgwcjdo]t[/color:dhgwcjdo][color=#00835E:dhgwcjdo]o[/color:dhgwcjdo][color=#008060:dhgwcjdo]m[/color:dhgwcjdo][color=#007C62:dhgwcjdo]i[/color:dhgwcjdo][color=#007963:dhgwcjdo]z[/color:dhgwcjdo][color=#007565:dhgwcjdo]e[/color:dhgwcjdo][color=#007267:dhgwcjdo]d[/color:dhgwcjdo] [color=#006B6A:dhgwcjdo]o[/color:dhgwcjdo][color=#00686C:dhgwcjdo]f[/color:dhgwcjdo][color=#00656D:dhgwcjdo]f[/color:dhgwcjdo][color=#00616F:dhgwcjdo]i[/color:dhgwcjdo][color=#005E71:dhgwcjdo]c[/color:dhgwcjdo][color=#005B73:dhgwcjdo]e[/color:dhgwcjdo] [color=#005476:dhgwcjdo]s[/color:dhgwcjdo][color=#005178:dhgwcjdo]y[/color:dhgwcjdo][color=#004D79:dhgwcjdo]s[/color:dhgwcjdo][color=#004A7B:dhgwcjdo]t[/color:dhgwcjdo][color=#00477D:dhgwcjdo]e[/color:dhgwcjdo][color=#00437E:dhgwcjdo]m[/color:dhgwcjdo][color=#004080:dhgwcjdo].[/color:dhgwcjdo][/b:dhgwcjdo]
        • BepB Offline
          Bep
          Hello Oscar,
          I forgot to mention that if possible,you should be able to exclude a part of a face from triangulation (this is not possible in mobilecad ,and thats the reason I cant use it)
          Greetings, Bep
          part excluded from triangulation.skp
          • OscarLokO Offline
            OscarLok
            Hi Bep, a4chitect & Gjenio
            There is a new 2D parametric geometry avi which lock the edges in the first POST . It show that how to make the trilateration. We start to do it by select a face, then we can lock the edge we want.
            By the way, we can adjust (or lock) which side(or both sides) to be adjusted.
            This is just a quick test. Don't know is it the correct way.
            If it is the right way, I will develope it further ! ๐Ÿ˜’
            Oscar
            • OscarLokO Offline
              OscarLok
              Hi Bep,
              May I know that do you receive my PM, please?
              Oscar
              • jujuJ Offline
                juju
                Hi Bep,
                Oscar
                Check you "outbox" in the User Control Panel (UCP), if the PM is no longer in your "outbox" the recipient has opened/received it.
                • OscarLokO Offline
                  OscarLok
                  Hi Juju
                  There are 3 PM in the "outbox" . May I know how to resend again, please?
                  Regards
                  Oscar
                  • jujuJ Offline
                    juju
                    You can't resend them, they've already been sent, the recipients have not looked at them yet, that is what it means when PM's remain in the "outbox".
                    • FletchF Offline
                      Fletch
                      Hi Oscar,
                      Here's the original thread where this topic was discussed. I realize what I'm referring to in that thread is possibly a bit more involved than what you're trying to do... perhaps not.
                      but my idea outlined here will make someone some money if they set the right price.
                      I know someone wrote a script to do this (Gaeius linked me to it), but they wanted a thousand dollars for it or more... and what they need to ask is a reasonable price for it... like $80 or something... then perhaps everyone could actually use it... giving it an elitist price only stifles development - IMHO.
                      I really think your script has a lot of potential.
                      Is there a way you could make the selection of points or faces to lock into a graphically interactive tool instead of the awkward pull-down menu? (like how it works with the Subdivide and Smooth tool)
                      Fletch
                      • BepB Offline
                        Bep
                        Hi Bep,
                        Oscar
                        Hi oscar,
                        As already posted to you in your PM-box, I instaled your test script succesfuly.
                        You should however have warned me about how great this script is.
                        I needed half an hour to get myself under control again.
                        Now my enthousiasme is somehow under control,I can give you some first, hopefully usefull remarks.
                        -Could you script preferbly use the users own units settings (my settings are Decimal, and cm for example.
                        -Could the defauld box to fill in when you want to adjust a line lenght be the size box.
                        (The most important for trilateration)
                        -If the first dimension of the sketcht triangle is changed, the hole figure should be scaled without losing the proportions of the initial sketch,like when scaling with the "tape measure"tool.
                        -The warning if you make size off a side of a triangle to large ,now is "the minimum size=..",
                        should it not be "max.size="?
                        Now I am going to take a beer and play around with your skript for a while.
                        If some other remarks come up I will post them tomorow.
                        Greetings,
                        Bep van Malde
                        • philemP Offline
                          philem
                          I have been following this thread basically since it started, and am very interested in this ruby.
                          Have I missed the release of it for downloading or is it still under development?
                          thanks
                          Just do it, it might be fun.
                          • OscarLokO Offline
                            OscarLok
                            Hi Bep,
                            *units setting should be no problem.
                            *proportions of the initial sketch can be figure out.
                            *"max.size=" will be done.
                            *Only I do not understand is :- ๐Ÿ˜ณ
                            Thanks for your feedback ๐Ÿ˜„
                            Oscar
                            Any feedback is welcome!
                            • OscarLokO Offline
                              OscarLok
                              O I see! โ˜€
                              Thank you! Juju
                              Oscar
                              • BepB Offline
                                Bep
                                Hi Oscar,
                                I just lookt at you post,and saw your question.
                                I attacht a picture to make clear what i mean.
                                greetings Bep
                                defauld box to fil in when you wont to edit a line lenght
                                • OscarLokO Offline
                                  OscarLok
                                  May I have a copy of the Building's program spreadsheet excel file, please ? (You can PM to me if you want.)
                                  Oscar
                                  • OscarLokO Offline
                                    OscarLok
                                    Hi Fletch,
                                    I have send you a PM to test.
                                    Any feedback are welcome! ๐Ÿ˜„
                                    Regards
                                    Oscar
                                    • OscarLokO Offline
                                      OscarLok
                                      Hi Fletch,
                                      As we agree with this :-
                                      @fletch said:
                                      Really awesome, Oscar, yes, let's post this to the whole forum for all to share ideas. I would love a custom answer for the way our firm handles the excel spreadsheet program, but really probably it's best for everyone if it's more universal... as I mentioned.
                                      but the fact you can read a spreadsheet from excel and draw spaces - that's really what I was looking to find out - and you did it! ๐Ÿ˜
                                      Now, I have a format of it. Any feedback are welcome! I will do a quick script(spreadsheet to SU) for it.
                                      Regards
                                      Oscar
                                      Universal Format.xls
                                      • FletchF Offline
                                        Fletch
                                        cool! looks like it has great potential!!!
                                        you have 2 different fantastic tools going here now. ๐Ÿ˜†
                                        I think you will need to also attach your ruby that builds using your excel spreadsheet so people can test/understand/give feedback. ๐Ÿ˜‰
                                        %(#BF4040)[actually using the .rbs file you had me test, I am unable to open the "Universal Format.xls" because after I gave it the location of the previous test file, that's all it will use.
                                        So I am anxiously awaiting your script to test.]
                                        Fletch
                                        • OscarLokO Offline
                                          OscarLok
                                          Hi Fletch,
                                          I will further modify the script for testing soon. ๐ŸŽ‰
                                          I am doing some CAD/CAM scripts for my CNC production.
                                          Sorry for you to keep waiting, give me some time, please! ๐Ÿ˜‰
                                          Oscar
                                            marcosrodrigues
                                            This script is still under development? maybe another with this same 2D approach?
                                            | menos รฉ mais
                                            • 2 / 3
