    Geomatry Resizer or Paramatric???
    43 Posts 14 Posters 8.4k Views 14 Watching
    • OscarLokO
      OscarLok
      Hi Bep, a4chitect & Gjenio
      There is a new 2D parametric geometry avi which lock the edges in the first POST . It show that how to make the trilateration. We start to do it by select a face, then we can lock the edge we want.
      By the way, we can adjust (or lock) which side(or both sides) to be adjusted.
      This is just a quick test. Don't know is it the correct way.
      If it is the right way, I will develope it further ! 😒
      Oscar
      [b:dhgwcjdo][color=#0080BF:dhgwcjdo]JAYA Design & Renovation Sdn. Bhd.[/color:dhgwcjdo][/b:dhgwcjdo] [b:dhgwcjdo][color=#00BF40:dhgwcjdo]T[/color:dhgwcjdo][color=#00BC42:dhgwcjdo]h[/color:dhgwcjdo][color=#00B843:dhgwcjdo]e[/color:dhgwcjdo] [color=#00B247:dhgwcjdo]e[/color:dhgwcjdo][color=#00AE48:dhgwcjdo]x[/color:dhgwcjdo][color=#00AB4A:dhgwcjdo]p[/color:dhgwcjdo][color=#00A84C:dhgwcjdo]e[/color:dhgwcjdo][color=#00A44D:dhgwcjdo]r[/color:dhgwcjdo][color=#00A14F:dhgwcjdo]t[/color:dhgwcjdo] [color=#009A53:dhgwcjdo]i[/color:dhgwcjdo][color=#009754:dhgwcjdo]n[/color:dhgwcjdo] [color=#009058:dhgwcjdo]c[/color:dhgwcjdo][color=#008D59:dhgwcjdo]u[/color:dhgwcjdo][color=#008A5B:dhgwcjdo]s[/color:dhgwcjdo][color=#00865D:dhgwcjdo]t[/color:dhgwcjdo][color=#00835E:dhgwcjdo]o[/color:dhgwcjdo][color=#008060:dhgwcjdo]m[/color:dhgwcjdo][color=#007C62:dhgwcjdo]i[/color:dhgwcjdo][color=#007963:dhgwcjdo]z[/color:dhgwcjdo][color=#007565:dhgwcjdo]e[/color:dhgwcjdo][color=#007267:dhgwcjdo]d[/color:dhgwcjdo] [color=#006B6A:dhgwcjdo]o[/color:dhgwcjdo][color=#00686C:dhgwcjdo]f[/color:dhgwcjdo][color=#00656D:dhgwcjdo]f[/color:dhgwcjdo][color=#00616F:dhgwcjdo]i[/color:dhgwcjdo][color=#005E71:dhgwcjdo]c[/color:dhgwcjdo][color=#005B73:dhgwcjdo]e[/color:dhgwcjdo] [color=#005476:dhgwcjdo]s[/color:dhgwcjdo][color=#005178:dhgwcjdo]y[/color:dhgwcjdo][color=#004D79:dhgwcjdo]s[/color:dhgwcjdo][color=#004A7B:dhgwcjdo]t[/color:dhgwcjdo][color=#00477D:dhgwcjdo]e[/color:dhgwcjdo][color=#00437E:dhgwcjdo]m[/color:dhgwcjdo][color=#004080:dhgwcjdo].[/color:dhgwcjdo][/b:dhgwcjdo]
      • OscarLokO
        OscarLok
        Hi Bep,
        May I know that do you receive my PM, please?
        Oscar
        • jujuJ
          juju
          Hi Bep,
          Oscar
          Check you "outbox" in the User Control Panel (UCP), if the PM is no longer in your "outbox" the recipient has opened/received it.
          • OscarLokO
            OscarLok
            Hi Juju
            There are 3 PM in the "outbox" . May I know how to resend again, please?
            Regards
            Oscar
            • jujuJ
              juju
              You can't resend them, they've already been sent, the recipients have not looked at them yet, that is what it means when PM's remain in the "outbox".
              • FletchF
                Fletch
                Hi Oscar,
                Here's the original thread where this topic was discussed. I realize what I'm referring to in that thread is possibly a bit more involved than what you're trying to do... perhaps not.
                but my idea outlined here will make someone some money if they set the right price.
                I know someone wrote a script to do this (Gaeius linked me to it), but they wanted a thousand dollars for it or more... and what they need to ask is a reasonable price for it... like $80 or something... then perhaps everyone could actually use it... giving it an elitist price only stifles development - IMHO.
                I really think your script has a lot of potential.
                Is there a way you could make the selection of points or faces to lock into a graphically interactive tool instead of the awkward pull-down menu? (like how it works with the Subdivide and Smooth tool)
                Fletch
                • BepB
                  Bep
                  Hi Bep,
                  Oscar
                  Hi oscar,
                  As already posted to you in your PM-box, I instaled your test script succesfuly.
                  You should however have warned me about how great this script is.
                  I needed half an hour to get myself under control again.
                  Now my enthousiasme is somehow under control,I can give you some first, hopefully usefull remarks.
                  -Could you script preferbly use the users own units settings (my settings are Decimal, and cm for example.
                  -Could the defauld box to fill in when you want to adjust a line lenght be the size box.
                  (The most important for trilateration)
                  -If the first dimension of the sketcht triangle is changed, the hole figure should be scaled without losing the proportions of the initial sketch,like when scaling with the "tape measure"tool.
                  -The warning if you make size off a side of a triangle to large ,now is "the minimum size=..",
                  should it not be "max.size="?
                  Now I am going to take a beer and play around with your skript for a while.
                  If some other remarks come up I will post them tomorow.
                  Greetings,
                  Bep van Malde
                  "History is written by the winners"
                  • philemP
                    philem
                    I have been following this thread basically since it started, and am very interested in this ruby.
                    Have I missed the release of it for downloading or is it still under development?
                    thanks
                    Just do it, it might be fun.
                    • OscarLokO
                      OscarLok
                      Hi Bep,
                      *units setting should be no problem.
                      *proportions of the initial sketch can be figure out.
                      *"max.size=" will be done.
                      *Only I do not understand is :- 😳
                      Thanks for your feedback 😄
                      Oscar
                      Any feedback is welcome!
                      • OscarLokO
                        OscarLok
                        O I see! ☀
                        Thank you! Juju
                        Oscar
                        • BepB
                          Bep
                          Hi Oscar,
                          I just lookt at you post,and saw your question.
                          I attacht a picture to make clear what i mean.
                          greetings Bep
                          defauld box to fil in when you wont to edit a line lenght
                          • OscarLokO
                            OscarLok
                            May I have a copy of the Building's program spreadsheet excel file, please ? (You can PM to me if you want.)
                            Oscar
                            • OscarLokO
                              OscarLok
                              Hi Fletch,
                              I have send you a PM to test.
                              Any feedback are welcome! 😄
                              Regards
                              Oscar
                              • OscarLokO
                                OscarLok
                                Hi Fletch,
                                As we agree with this :-
                                @fletch said:
                                Really awesome, Oscar, yes, let's post this to the whole forum for all to share ideas. I would love a custom answer for the way our firm handles the excel spreadsheet program, but really probably it's best for everyone if it's more universal... as I mentioned.
                                but the fact you can read a spreadsheet from excel and draw spaces - that's really what I was looking to find out - and you did it! 😍
                                Now, I have a format of it. Any feedback are welcome! I will do a quick script(spreadsheet to SU) for it.
                                Regards
                                Oscar
                                Universal Format.xls
                                • FletchF
                                  Fletch
                                  cool! looks like it has great potential!!!
                                  you have 2 different fantastic tools going here now. 😆
                                  I think you will need to also attach your ruby that builds using your excel spreadsheet so people can test/understand/give feedback. 😉
                                  %(#BF4040)[actually using the .rbs file you had me test, I am unable to open the "Universal Format.xls" because after I gave it the location of the previous test file, that's all it will use.
                                  So I am anxiously awaiting your script to test.]
                                  Fletch
                                  • OscarLokO
                                    OscarLok
                                    Hi Fletch,
                                    I will further modify the script for testing soon. 🎉
                                    I am doing some CAD/CAM scripts for my CNC production.
                                    Sorry for you to keep waiting, give me some time, please! 😉
                                    Oscar
                                      marcosrodrigues
                                      This script is still under development? maybe another with this same 2D approach?
                                      | menos é mais
                                      • 2 / 3
