    Miter Cuts
    2 Posts 2 Posters 5.9k Views 2 Watching
      Carlosq
      OK, so I should post on Newbie group but I figure you guys are experts and perhaps have the answer to my questions right at your finger tips, so here I go.
      How do I make miter cuts using SU?
      Thanks,
      Carlos
      • Jean-FrancoJ Offline
        Jean-Franco
        Hi, you've to use a cutting plane and then select "intersect with the model". Then a bit of cleanUp and it's done.
        Note: normally you should reverse the blue faces but they are just there for better understanding.
        Graphic tutorial
        Jean-Franco
