Miter Cuts
OK, so I should post on Newbie group but I figure you guys are experts and perhaps have the answer to my questions right at your finger tips, so here I go.
How do I make miter cuts using SU?
Thanks,
Carlos
Hi, you've to use a cutting plane and then select "intersect with the model". Then a bit of cleanUp and it's done.
Note: normally you should reverse the blue faces but they are just there for better understanding.
