    Side table with Louis XV style legs
    12 Posts 5 Posters 4.4k Views 5 Watching
    • Jean-FrancoJ Offline
      Jean-Franco
      Hi Folks,
      another attempt with some elegant legs.
      The skippy file
      Top view
      Jean-Franco
      • boofredlayB Offline
        boofredlay
        Oooo, sexy legs Jean ๐Ÿ˜‰
        Hey, what are these?
          Jean-Franco
          Hey Eric, why showing my secret boxes to everybody ๐Ÿคฃ
          Jean-Franco
            boofredlay
            Oops, I am sorry for undressing Louis online ๐Ÿ˜ฎ
            • G Offline
              Gidon Yuval
              Another beautiful piece, Jean.
              Do you use 'intersect with model' to make those legs? It's how I do it.
              If you don't know where you're going, you're never going to get there.
                Jean-Franco
                Hi Gidon,
                yes intersect with model is my way too. Nothing extraordinary but it works very well. Youv'e just to be fine drawing the shape. Bezier curves are perfect for that.
                Two pictures how to proceed.
                Jean-Franco
                • G Offline
                  Gidon Yuval
                  I do it the same way............. only in English ๐Ÿคฃ
                    Jean-Franco
                    For a Queen Ann leg most probably ๐Ÿคฃ
                    Jean-Franco
                    • ChiefwoodworkerC Offline
                      Chiefwoodworker
                      Jean-Franco
                      A beautiful piece of modeling. Do you also craft all these pieces you are showing us? Do you have a website I can look at?
                      Joe....
                      http://www.srww.com
                      • N Offline
                        nuclearmoose
                        Here is my translation of Jean-Franco's instructions on the images:
                        First image:
                        Start by drawing the shape of the leg. Use a grid to help determine the overall dimensions. Use Bezier curves for the shape; there is a free script available for download on the Internet.
                        (Here is a link to one of the plugins: Bezier Curve Ruby Script from Google)
                        Push/pull.
                        Straighten the upright form with the move tool. (Not sure if that is the tool he meant.)
                        To make it easy to handle, create a group or component.
                        Create a copy of the form and rotate it 90 degrees.
                        Second image:
                        Group the two elements. Select all, then explode, and finally intersect with model.
                        Clean up by eliminating unnecessary parts.
                        Here is the form you made!
                        Now you soften the edges.
                        The finished Louis XV leg!
                        I hope that this is close to Jean-Franco's intended instructions, and I hope that someone will find this useful.
                          Jean-Franco
                          Dear Craig,
                          thank you for that kind translation.
                          The method used is very common and well known in Sketchup, I think.
                          Anyway some Newbie may find it useful.
                          Jean-Franco
                          • N Offline
                            nuclearmoose
                            Jean-Franco,
                            Thank you for sharing your expertise with us! By the way, I'm one of the newbies that will benefit from your illustrations! ๐Ÿ˜„
