    Favourite Recipes
    2 Posts 2 Posters 253 Views 2 Watching
      remus
      Share your untold secrets, mroe so if they're tasty recips ๐Ÿ˜„
      To start:
      Swetcorn fritters for 2
      2 tbsp flour
      2 eggs
      milk
      1 tin sweetcorn
      cheese
      mix the flour and eggs togther thoroughly, add milk untill youve got a thick batter. Drain the sweetcorn and add it to the batter, mix well. Add a good handful of cheese to the mixture and stir well.
      To cook: get a frying pan with a tbsp of oil over a medium heat, spoon the mixture into palm sized fritters, they should be about 1cm thick. Fry untill golden brown and then flip and repeat.
      http://www.jamboree.freedom-in-education.co.uk/images/cooking/sweetcorn.jpg
      • P Offline
        pmiller
        The Best Brownies Ever (no fooling)
        4 large eggs
        1 cup sugar
        1 cup brown sugar
        1-1/4 cups unsweetened cocoa powder
        1/2 cup all purpose flour
        1/4 teaspoon table salt
        8 ounces melted unsweetened butter (2 whole sticks)
        2 teaspoons vanilla extract
        Preheat the oven to 300 degrees F. Line an 8-inch square pan with non-stick aluminum foil โ€“ dull side up to make a โ€œslingโ€ for removing brownies when done.
        In a mixer fitted with a whisk attachment, beat the eggs at medium speed until fluffy and light yellow. Add both sugars. Add remaining dry ingredients, and mix to combine. Add vanilla then the melted butter (slowly) and mix until incorporated.
        Pour the (very thick and sticky) batter into a lined 8-inch square pan and bake for 45 โ€“ 50 minutes. Check for doneness with the tried-and-true toothpick method: a toothpick inserted into the center of the pan should come out clean. When it's done, remove to a rack to cool. After about 5 minutes, lift the brownies out the pan by the aluminum foil sling and leave on the cooling rack. Resist the temptation to cut into it until it's mostly cool.
        Yield: 16 brownies
