    [Tutorial > Modeling] carbon nanotube
    26 Posts 7 Posters 14.8k Views 7 Watching
    • C
      caddict
      Inspired by Simon here's a shot at modelling a nanotube
      http://en.wikipedia.org/wiki/Carbon_nanotube
      It's not perfect - a bit of trial and error involved. This method is for the armchair variety. For the zigzag or chiral some tweaking would be needed.nanotube.jpg
      • GaieusG
        Hey Steve,
        Nice image but where is the tut itself? πŸ˜‰
        • C
          caddict
          oops!
          nanotube.skp
          • S
            Simon B
            Looks great! I'll inspect the tut when I get home πŸ€“
            • S
              Simon B
              Very elegant solution caddict. Mine involved converting a segmented cylinder but the tut I was working on was running to 20+ iterations so I'll defer to yours. πŸ’š
              • T
                Teezer
                Ok, you got me out of lurking status with this problem. I produced a result with the hexagon orientation rotated 30 degrees, which yielded a simple minimum structure that can be built with two circles that have their segments offset by half the segment length.
                You'll see what I mean by that when you look at the skp. I used a 36-segment circle, and went through a lot of trial and error before I got it just right.
                My wife said, "You're making a roll of chicken wire?" πŸ’š
                Nanotube.skp
                Real life is just another website, albeit a rather boring one.
                • T
                  Teezer
                  Playing with this problem some more, I did some arithmetic and figured out how to make a tube of hexagons of a specific size from two circles (actually four, by cloning the first two).
                  I don't know how to set up scenes yet, so I drew the steps along the red axis. Here's the text that would go with the skp:
                  To make a nanotube with hexagons of ~12" radius:
                  Draw a circle of 46" radius.
                  Drag/copy the circle 10 3/8".
                  Rotate the copy 7.5 degrees.
                  Group the two circles, and drag/copy the group 20 3/4".
                  Ungroup everything, and break the curves.
                  Hand stitch the hexagon pattern.
                  Delete the excess lines.
                  Elongate to taste.
                  Note: For a circle of 24 sides, the length of a side is the radius divided by 3.8333. For a given side, multiply by 3.8333 to get the radius.
                  Nanotube2.skp
                  • S
                    Simon B
                    Thanks very much Teezer. This was so similar to my own method I have run with your hint about scene creation and made a tutorial from your original file and posted text - hope you don't mind. Very nice solution.
                    Nanotube2tut.skp
                    • C
                      caddict
                      Yes, nice solution Teezer! And nice tut Simon. Teezer, please define "simple minimum solution". Is this a math term? A physics term?
                      It really makes sense to think of the hexagon vertices lying on a series of circles.
                      How about this refinement of your process.
                      1. Instead of drawing circles, draw polygons. In this case a polygon with 24 sides.
                      2. The "hand-stitching" process can be mechanized. Just draw two adjacent zigzags up the stack of polygons and multiple rotate/copy them around the perimeter(use rotate and control to get the + sign, click on the centre of the polygon which SU will find for you, start the rotation process, enter the relevant angle, then enter 6x)
                      Who would have thought a roll of chicken wire would be so absorbing
                      I couldn't help doing the math.
                      This method works because the distance from vertex to vertex across a hexagon equals twice the length of the side.
                      For a nanotube with N repeat units, we need a polygon with 3N sides.
                      The angle at the centre of this polygon is A = 360/3N
                      So the point is that we can now build a nanotube with any number of repeat units, with a side of any length.
                      Of course the work is not over. What about the other types of nanotube? Armchair for example!
                      • T
                        Teezer
                        Nice tut Simon! No, I don't mind at all. πŸ’š
                        And apologies to caddict for hijacking the thread. I just got engrossed in trying to find a simple solution, since the object is made of a very basic set of components that repeat in a simple pattern. My "simple minimum" comment meant that the small section that I isolated in the first model was all the construction that was needed -- the rest was copy and paste (in fact, what was shown was too much if copy, paste, rotate was used, and too little for just copy paste -- duh).
                        I had a trig reference around somewhere, but it's been fifty years. πŸ˜’ I'll take your word on the math.
                        Off to look up an "armchair nanotube"...
                        • C
                          caddict
                          I don't think you hijacked the thread...it's a team effort! The great thing is that there's always more than one way to solve any problem.
                          • T
                            Teezer
                            Ok, my obsession with carbon nanotubes is officially over. We had already created Armchair and Zigzag nanotubes in the earlier efforts, and all that remained to be done was to create a model of a Chiral nanotube. I finally managed it last night. 😍
                            Here is a skp with all three models:
                            NanoThree.skp
                            • C
                              caddict
                              Nice Teezer! You have staying power πŸ˜„
                              The chiral looks tasty. But you only gave us the briefest desciption of how you made it. Give us more details if you can face it!
                              • T
                                Teezer
                                I was afraid you'd want to see how this sausage was made, so I saved some of the steps along the way. And I figured out the "scenes" thing and put together as a tut in the more-or-less traditional manner.
                                Doing it again would just be tedious. The fun part was figuring out how to get it done. I love to solve problems like this... πŸ’š
                                NanoChiralTut.skp
                                • S
                                  Simon B
                                  Thanks Teezer, I have never heard of chiral nanotubes
                                  • C
                                    caddict
                                    Yes very nice solution Teezer, And very thorough. Also nice tut. The rolling process you used is accurate but I can see tedious. I guess you know about the two methods of box selection: from the left and from the right. That could speed things up. You may get a job at MIT πŸ˜„
                                    • T
                                      Teezer
                                      I'm assuming that you meant I could have rolled it from both sides toward the center. Yes, that would probably make it easier. I was so glad to finally get a good result that I didn't even think about improving the process -- who would want to do this on purpose? πŸ˜‰
                                      And I'm not looking for a job at all. I've (almost) retired from 45 years of computer programming, and I'm looking forward to just playing with computer graphics and building stuff... πŸ’š
                                      • C
                                        caddict
                                        I wasn't thinking you could improve your method. I was just wondering whether you know the various methods of selecting objects. See here:
                                        http://download.sketchup.com/OnlineDoc/gsu6_win/gsuwin.html
                                        I think your solution is great πŸ˜„
                                        If I think of any good problems I'll send them your way.
                                        • R
                                          Roger
                                          The circle tool and the polygon tool are identical and the default size for the circle tool is 24 sides. Also the area calculation for circles is not based on the area of a circle of a given radius, it is based on a polygon with the number of sides specified in your circle tool.
                                          Using trigomometry,[attachment=0:12cafquj]<!-- ia0 -->nanotube the math.jpg<!-- ia0 -->[/attachment:12cafquj]
                                          http://www.azcreative.com
                                          • C
                                            caddict
                                            It still needs work imo.
                                            I'm trying to figure out a neat way to produce a perfect model ie all bond lengths equal.
                                            For a fixed bond length and number of repeat units, the variables are: bend angle of the hexagons, and radius of the nanotube. There is obviously a relationship between them.
                                            And also it would be nice to model the other types of nanotube. 😎
                                            • 1 / 2
