    Some COOL Gadgets!
    4 Posts 3 Posters 490 Views 3 Watching
    • Mike LuceyM Offline
      Mike Lucey
      This clock should keep things in perspective, its the LifeClock!
      %(#000080)['Most clocks, the ones that are based around seconds, minutes, and hours, can be watched for movement if you really need to waste some time of boredom, though we’ve seen clocks which are both much more fun, and more beautiful to look at than your average clock. The Lifetime Clock, on the other hand, is based on years. The movements of the hand are so slow (1/61320th of a normal clock speed) that you’ll need a time lapse camera to spot any clear movement, so you might want to grab a book instead.
      Each number on its face is separated by 7 years of your life, and you’ll have to live a full 84 long years until you can see one full revolution around the dial. That’s a lot of children to throw off your lawn. — Andrew Dobrow']
      and
      Never Jump In A Cold Shower Again! Temperature Controlled LED Shower Light
      Shower Light lets you know when the water is getting hot! Turn the water "on" and a flood of blue light shines down through the shower stream - cool blue refreshing. When the water gets "hot" (89 F/32 C), the LED lights change from blue to red, letting you know that the water is hot and ready!
        remus
        I notice the life colcok doesnt run on battries 😎 and i wish i had one of those when i was born, thatd be really cool, just to see it move through your life.
          toxicvoxel
          Mike, you're not fooling anybody with the age on your clock...
          • or does it show the time that's left?
            Mike Lucey
            😆 I'd be doing very well if I had that much time left!
            It's about 30 years, putting me at a check-out age at 87 😉
