    Sine Curve (wave) script?
    24 Posts 6 Posters 5.3k Views 6 Watching
    • JClementsJ Offline
      JClements
      Hi Gata.
      I do use the copy along path script and it works nicely. But the trick here is to space (subdivided) equi-distant if you will, along an existing curve. The functions that Fred06 has provided are flexible enough to aid in doing this, plus, re-manipulate/smooth some complex curves.
        Jim
        @jclements said:
        Thanks, all!
        Jim, about the code you posted.
        Is that a snippet from a Ruby script and can it be run from the Ruby console window? Or, could a Sine Script be written that asks user for unit of measure, length and amplitude and maybe the number segments?
        John
        John,
        301 Moved Permanently
        (www.sketchucation.com)
          JClements
          Thank you, Jim!
          It works beautifully.
          Regards, John
            Jim
            I have updated the script to make it remember values between calls.
            • 2 / 2
