    Sine Curve (wave) script?
    24 Posts 6 Posters 6.4k Views 6 Watching
    • JClementsJ
      JClements
      Hi Gata.
      I do use the copy along path script and it works nicely. But the trick here is to space (subdivided) equi-distant if you will, along an existing curve. The functions that Fred06 has provided are flexible enough to aid in doing this, plus, re-manipulate/smooth some complex curves.
        Jim
        @jclements said:
        Thanks, all!
        Jim, about the code you posted.
        Is that a snippet from a Ruby script and can it be run from the Ruby console window? Or, could a Sine Script be written that asks user for unit of measure, length and amplitude and maybe the number segments?
        John
        John,
        404 Not Found
        (www.sketchucation.com)
        • JClementsJ
          JClements
          Thank you, Jim!
          It works beautifully.
          Regards, John
            Jim
            I have updated the script to make it remember values between calls.
            404 Not Found
            • 2 / 2
