Global/Local (component) axis
I'm trying to create a keystroke (or context menu command) to call the "Show Component Axes" option under Model Info/Components.
Does anyone know what this is?
By sorting out the current Axis-related items, I created this reference list:
Move Global Axes
desc: moves axis
key: "Tools/Axes"
code: { Sketchup.send_action "selectAxisTool:" }Toggle Global Axes
desc: show/hide global axis
key: "View/Axes"
code: { Sketchup.send_action "viewShowAxes:" }Reset Global Axes
desc: reset global axis to 0,0,0
key: "View/Reset axis (World)"
code: ?Context Menu (over global axis):
- Place= desc: see "Axes tool" above
- Move= desc: Dialog Box (X,Y,Z)
...code: ?
- Reset= desc: see "Reset Axes" above
- Align= desc: Top view, centered on global axis
...code: ?
- Hide= desc: see "View Axes" aboveMove Local Axes
desc: move component axis
key: "Edit/Item/Change Axes"
code: ?"Toggle Local Axes"
desc: show component axis (in Model Info/Components)
key:
code: ?Toggle Edges Axis
desc: color X,Y,Z axis-aligned edges
key: "View/Rendering/Edge/By Axis"
code: ?Display Tool Crosshairs
desc: show/hide Tool crosshairs (in Preferences/Drawing)
key: "Drawing/Display Crosshairs"
code: ? -
Sketchup.active_model.rendering_options["DisplayInstanceAxes"]=true
will display components axes, and guess what
Sketchup.active_model.rendering_options["DisplayInstanceAxes"]=false
will do ? -
Thanks Didier!
I was able to generate a quick test menu for these options with your direction:
require 'sketchup.rb' ######################################### if( not file_loaded?("Menu_Axis.rb") ) ### CONTEXT MENU UI.add_context_menu_handler do | menu | submenuz=menu.add_submenu("Axis...") submenu01=submenuz.add_item("Move Global Axis") { Sketchup.send_action "selectAxisTool;" } submenu02=submenuz.add_item("Toggle Global Axis") { Sketchup.send_action "viewShowAxes;" } submenu03=submenuz.add_item("Reset Global Axis ...?") { UI.messagebox("Missing Command!") } submenu04=submenuz.add_item("XYZ Global Axis ...?") { UI.messagebox("Missing Command!") } submenu05=submenuz.add_item("Align to Global Axis ...?") { UI.messagebox("Missing Command!") } submenuz.add_separator submenu06=submenuz.add_item("Move Local Axis ...?") { UI.messagebox("Missing Command!") } submenu07=submenuz.add_item("Toggle Local Axis") { if Sketchup.active_model.rendering_options["DisplayInstanceAxes"] Sketchup.active_model.rendering_options["DisplayInstanceAxes"]=false else Sketchup.active_model.rendering_options["DisplayInstanceAxes"]=true end } submenuz.add_separator submenu08=submenuz.add_item("Toggle Edge Axis") { if Sketchup.active_model.rendering_options["EdgeColorMode"] Sketchup.active_model.rendering_options["EdgeColorMode"]=1 else Sketchup.active_model.rendering_options["EdgeColorMode"]=2 end } submenu09=submenuz.add_item("Toggle Tool Crosshairs ...?") { UI.messagebox("Missing Command!") } end #do end #if #----------------------------------------------------------------------------- file_loaded("Menu_Axis.rb") ###...although the EdgeColorMode doesn't want to toggle back and forth (hm!)
I poked through the API, but didn't find anything immediate that suggested the RESET, or TOOL CROSSHAIRS.
Maybe a "view.invalidate" instruction will refresh the view after edges mode toggle ?
Hmm, didn't do the trick.
Looks like I have to code a function that gets the value then checks it before changing it. I thought I could skip this bit (based on the above example for ["DisplayInstanceAxes"]=false/true).
You have a line near the end of your code:
if Sketchup.active_model.rendering_options["EdgeColorMode"]Since that will always return true (non-nil), then it always evaluates the first conditional. That's why it doesn't ever toggle.
Register LoginAdvertisement
