    TIN Tube
    9 Posts 3 Posters 2.2k Views 3 Watching
    • F Offline
      fbartels
      To make curvy tube geometry I've always had to resort to using the Follow-Me tool. There is another way that avoids some of the issues involved with Follow-Me. It's done by making a 12 sided (you could do any number of sides) tube where each side is a TIN. This creates tube geometry that the Smoove tool can shape easily. I've attached a model with a tube that you can experiment with.
      simple TIN tube.skp
      • W Offline
        watkins
        Dear Fred,
        Do you think you could put a simple tut together showing how you use the sandbox tools to make the beam/tube? I ask because I have never used these tools before.
        To use a little used expression, "Thank you in anticipation of.."
        Kind regards,
        Bob
          Am i right when I explode your Tin tube uploaded before use the Smoove tool?
          PS Have you made a special "tuts section" inside your Web site?
          • F Offline
            fbartels
            Hi Pilou,
            Better to just double click to enter the group and then you can use Smoove within the group.
            Nope, but I'll consider adding. πŸ˜„
            Fred
              @Fred
              you right: that is more practical indeed! πŸ˜„ 😎
              • F Offline
                fbartels
                @watkins said:
                Dear Fred,
                Kind regards,
                Bob
                Bob, I made a quick screenshot movie here. I had the usual little SketchUp issues while making the movie which I left in to provide some verisimilitude. πŸ˜‰
                  Tricky! πŸ€“
                  If I find more speedy, I will come back with it πŸ˜„
                    OK this one is more speedy πŸ˜„
                    • F Offline
                      fbartels
                      Pilou,
                      Excellent! That makes perfect sense. Never occurred to me but certainly much quicker.
                      Pilou, yesterday I tried to make a spiraling TIN tube by cutting what a thought was a properly angled segment from the TIN tube and duplicating it. I couldn't get the pieces to match up perfectly so I gave up. Perhaps you might have some ideas how to accomplish?
                      Fred
