    Divide_Cpoint.rb > Question for Didier Bur
    11 Posts 2 Posters 3.2k Views 2 Watching
    • JClementsJ Offline
      JClements
      Hi Didier:
      1- Would it be possible for this script to work on Polylines (arcs, circles, "welded" segments, etc.) as well?
      2- It looks like you are able to load the script without specifying the .rb name, correct?
      What part of the code enables the script to be loaded then?
      Regards, John
      • Didier BurD Offline
        Didier Bur
        Hi John,
        Why not ? I will look into it when I've some time.
        No, it's a regular rb and if it is not in the Plugins folder it won't load.
        Maybe you are talking about the fact that it "loads on demand" via the context menu when a valid selection is active ?
        DB
          JClements
          "No, it's a regular rb and if it is not in the Plugins folder it won't load.
          Maybe you are talking about the fact that it "loads on demand" via the context menu when a valid selection is active ?"
          Yes that must be it. I don't think I've ever investigated "load on demand" before.
          a) So what code segment specifically tells SU to load this script?
          b) And I take it that model.start_operation "Divide with construction points" defines what is shown in the menu, correct?
          Reason I ask is that I almost always change the menu name displayed by adding the script's file and author in brackets; for example, "Add Construction Points at Equal Intervals [Divide_CPoint.rb Didier Bur]. Even though my menus get rather large, its easy for me to identify which script is responsible for a particular menu item.
            Didier Bur
            None. The script IS loaded from SU start, BUT the option appears in the context menu only under precise circumstances. Here the "divide_cpoint_valid_selection" function checks for a selection of 1 element of type "Edge".
            Nope. It's the label after the "Undo" in the Edit menu when you undo the operation. It tells SU to "memorize" all what's hapenning from that point until the "commit_operation" statement in the code, to further undo it globally if needed.
            If you want to change the menu, go to the line
            menu.add_item("Divide with construction points") { divide_cpoint } and edit between the quotes.
            Regards,
            DB
              JClements
              Thanks Didier, for taking the time to explain.
              Ingenious how it works.
              Regards, John
                JClements
                Works great, thanks.
                You know what this leads to ... an option to explode the line/arc/circle at construction points. :}?
                  Didier Bur
                  I also add a quarter of an hour "free time" to implement arcs and circles
                  Polylines are more tricky...
                  Download it here (same link than first version):
                  http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=5633&p=32173#p32173
                  DB
                    Didier Bur
                    Do-able. Wait 5 mn 🤣
                    Edit: Explode working for lines, arcs, circles.
                    DL here 'same link than previous versions):
                    DB
                      JClements
                      Didier, it kind of works.
                      Try the attached .skp; 3-segmented arc with points for 7 divisions.
                      Similar results with other arcs.
                      Some vertices without a point are divided and segments with points not being divided. Divisions that are defined by begining with a point, then a vertex, and end with a point are not equal in length to other divisions.
                      I just tried dividing a 3-segment arc into 11 divisions, the last division got deleted.
                      Also could cpoints be automatically group?
                      3line curve with 7 points.skp
                        Didier Bur
                        Updated.
                        Should work OK now, BUT, it is unfortunately impossible to rebuild several curves between cpoints, because new segments to draw do not have the same lengthes within a sub-curve, so there's no way to retrieve the same curve than the original.
                        Regards,
                        DB
                          JClements
                          Merce, Didier.
                          Regards, John
