    Why this error...?
    6 Posts 3 Posters 917 Views 3 Watching
      lapx
      Need help removing errors. All ruby's are in pplugin folders why this error message?
      • Didier BurD Offline
        Didier Bur
        For parametric.rb: open the script which calls parametric.rb and remobe the ./ before parametric.rb:
        the line: require ./parametric.rb must be require parametric.rb
        For mesh_additions.rb, it seems the file is missing in your Plugins folder. Check for it.
        Hope this helps,
        DB
          lapx
          Thanks DB! That cleared up some of it. Now I'm getting this. Almost there... 😄
            azuby
            Btw. pressing ALT+Print (or whatever the screenshot key is named) makes a screenshot only from the active window.
            azuby
              Didier Bur
              Mmm, what a mess with your scripts... or in stair_maker062.rn itself
              The method named "add_item" builds the Tools menu, adding new items in it.
              I presume the offending line is this one, just near the end of the script:
              submenu.add_item("Wood straight stair") { archetypesElements_straightWoodStair }
              submenu is undefined at this step and is nil.
              Please call Christophe Hébert for some help/debug.
              DB
                lapx
                Thanks Didier,
                I may just unload this puppy unitil I can get a fix.
