    Add Scene Bug Fix
    1 Posts 1 Posters 540 Views 1 Watching
    • CadFatherC
      CadFather
      noticed how everytime you close su the keyboard shortcut for add scene disappears? no? πŸ˜’ sure you can set it again next time you open it up..and the next...and the next..you get the picture. so in case anyone finds it useful as i do, here's my fix:
      (strictly speaking not a ruby - but thought was a good place to post)
      "settings.reg" is the registry key where the "Add Scene" keyboard shortcut is stored
      (and only that key in this file, so it does not mess your setup)
      run it once and your Add Scene shorcut will finally stick - if you change computer or reinstall su, you can just run it again..
      my shortcut is F2 - you can change that in the reg file but you need to know a bit about registry..
      registry keys can be malicious - so you can open this one in notepad to make sure i won't buy my ski holiday with your hard work, though i'm always up for offers πŸ˜‰
      Add Scene Bug Fix.zip
