    LanguageHandler question
    3 Posts 2 Posters 695 Views 2 Watching
    • Didier BurD
      Didier Bur
      Hi all,
      Why is this not working ?
      $tStrings = LanguageHandler.new("Components.strings")
      And this is working:
      $tStrings = LanguageHandler.new("sandbox.strings")
      All other ".strings" files work, except this one. All are at the correct location.
      The message I get is the following:
      Error: #<NoMethodError: C:/PROGRA~1/Google/GOOGLE~4/Tools/LangHandler.rb:72:in ParseLangFile': private method gsub!' called for nil:NilClass>
      In LanguageHandler.rb, the line 72 is:
      	keyvalue[1].gsub!(";", "")
      So keyvalue[1] seems to be nil, but in reverse exploring the code, I can't see what's wrong with the file.
      All usual functions of this file work OK: components names are in french in the component browser and so on...
      Any idea someone ?
      Attached in the french components.strings file if you want to try it.
      Put it in your Resources/local_name folder
      (make a backup of yours first)
      DB
      • Al HartA
        Al Hart
        Try adding these 3 lines to the Langhandler.rb code.
        (The last 3 on the left)
                                   #pull out the key
                                        keyvalue = entryString.split("\"=\"")
        $keyvalue = keyvalue
        $entryString = entryString
        printf("'%s' '%s' '%s'\n", entryString, keyvalue[0], keyvalue[1])
        This will print out how it splits the entryString.
        and the two $variables let you examine whatever the last values were when it failed.
        It turns out that it fails on the line: "-- Runtime --" = "-- Durée d'exécution --";
        and the reason it fails, it because it is looking for: "=", and this line has: " = "
        (spaces around the equals signs.)
        Al Hart
        http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
        IRender nXt from Render Plus
        • Didier BurD
          Didier Bur
          Yep, that's it !
          Thanks Al. I was thinking that the strip method didn't care of spaces, and it does in fact.
          Since components.strings is the stock file that is installed with the french package of GSU: 👎 to SU Team 😉
          DB
