    Haven't posted anything in a while....
    8 Posts 5 Posters 669 Views 5 Watching
    • O Offline
      otb designworks
      Here is the most recent BOP (big 'ol project), way way WIP.
      Paul, you can see why I asked about your road workflow. I was hoping to god that you had some magical, non- brute force way to do it. ๐Ÿ˜„
      Suggestions and critique always desired and appreciated!
      18 meg file, so far, and rising quickly...
      Cheers, Chuck
      OTB Designworks is on Youtube
        bubbalove
        Great work! Try to get some more sunlight!
        "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
          mateo soletic
          The only suggestion and critique is that those new buildings seem to loom down on the small brick house neighbourhood.
          Wondering if it is right way to present them.
          A more subtle way perhaps a different colour, angle of view....
          Concept Illustrations
          • O Offline
            otb designworks
            Ha, that's funny. I was just thinking I was going to ask the principal if can lop a floor off all of the taller brownstones. There are other buildings with different heights, but I know what you mean by loom.
            I have the light turned down right now for modeling, but good point.
            My secret hope is I can manage to get the go a head to render, either out of Cheetah or Vue, probably Vue, because I would like to go nuts over the foliage.
            We'll see how the budget holds. The overall project is 160 acres with a maybe for 80 more. ๐Ÿ˜ฎ I am really enjoying the magnitude of this badboy.
            I think what the layman doesn't see is that there is a need for not only modeling ability, but also the essential black art of optimization while maintaining as an efficient editability as possible. Not to mention vast range of design decisions. It definitely can feel daunting at times.
            Cheers, Chuck
            • O Offline
              otb designworks
              I like the world you have created there and in particular the ground work to tie it all together. I agree that the big buildings should be more subtle. The only other thing is the bridge. If you could place a material that flows along the arch of the bridge then it would be more distinguishable.
              Nice job...post them more often please....cheers!!
              A material that follows the arch (throws up a little) that sounds like fun ๐Ÿ’š
              I appreciate your attention to detail... (adds arch detail to list.....)
              Cheers, Chuck
              • O Offline
                otb designworks
                Like the leaning tower of Kitzigen, Germany.
                The story there is they ran out of water for the mortar as they were building the coned roof, used beer instead, and now it leans quite a few degrees.
                Cheers, Chuck
                • Paul RussamP Offline
                  Paul Russam
                  Couple of ideas:
                  Try making the glass a dark blue colour instead of the white.
                  Make the Tarmac darker, I've got the pavement darker than the road as the road get a lot more traffic/wear.
                  Shove in as much to break up the uniformity, in my case: lamp posts, bus stops, phone boxes, traffic lights, road signs etc. and place them unevenly.
                  Add 'things' where walls meet floors. You could hide the junction with a hedge or change the bottom 3,4,5,6 brick courses to a different stock etc. For internal views I add a 15mmx150mm skirting board to all rooms, it makes a world of difference to the perception.
                  If you've got any wall on the site, add some steps to their height to break up their profile and make the shadows more interesting. You only need to step up the wall 150mm and then back down again elsewhere.
                  Hope this helps
                  Paul Russam
                  English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                  • O Offline
                    otb designworks
                    Thanks, Paul, for the great advice.
                    I am just about to start populating this quadrant with "stuff"; I have been looking forward to this for weeks. I think trees will make a huge difference, too.
                    My glass is opaque, since all of the buildings are just shells, but I will experiment with a bluer glass and see what it looks like.
                    I am torn with the pavement. Right now, I am just using a solid color because I find that the asphalt textures really flicker badly when animating. I agree that I need to do something to make the roads look more realistic.
                    Thanks again for taking the time to jot down your suggestions.
                    Cheers, Chuck
