    Re-Vue's
    17 Posts 6 Posters 1.9k Views 6 Watching
    • soloS Offline
      solo
      I wrote Vue off last year as it never worked within my flow, however I have decided to give it another go, I have seen some great interior renders here and on e-on's pages, so I will give a few goes at natural lighting and lit interior scenes.
      The first below, has a standard off the shelf poser character 'James', Vue exterior and all modelled and textured Sketchup building and props.
      http://img340.imageshack.us/img340/4497/jamesinpaintroompn7.jpg
      http://www.solos-art.com
      • soloS Offline
        solo
        Sunset
        http://img480.imageshack.us/img480/5817/jamesinpaintroom1pk4.jpg
        • H Offline
          holgster
          Looks like you used the standard lighting model. Try using the radiosity setting for a more convincing lighting of the interior.
          Drawback is that the render time will increase dramatically
          • jenujacobJ Offline
            jenujacob
            doubt : is GI in play here?? or is it standard scanline render?
            • soloS Offline
              solo
              I tried using GI but render times were rediculous, I used standard sun settings. The next render (in oven at moment) should be more spectacular as it's a night scene with a few different types of interior lighting methods.
              I have had Vue for over a year but in total I have probably only used it 20 hours, so every render should be better than the one before...at least thats my intent.
              • soloS Offline
                solo
                I had fun with this one, the TV glow came out right, I fiddled with the other lights a bit...um..not too bad for an app that I thought could not handle interiors well.
                http://img520.imageshack.us/img520/5489/vuuuuagf4.jpg
                • soloS Offline
                  solo
                  Thanks James, those were your Bond days 😎
                  This is also done with Vue, it was modelled by SchreiberBike.
                  http://img521.imageshack.us/img521/4523/gr4tehyrhu9.jpg
                  • K Offline
                    kwistenbiebel
                    I am so jealous about your skills to pose and rig characters....you just seem to pull them out of your sleeve as if it's nothing .
                    The scene setup in the shot with the guy watching telly is really nice.
                    I wonder how it would look like if rendered with Vray or Podium.
                    Cheers,
                    Kwistenbiebel
                    • soloS Offline
                      solo
                      Thanks guys...
                      I would like to try v-ray but my trial ended before I had a chance to try it...
                      I may try it with Modo, as I have installed the trial version.
                      Sunrise.
                      http://img185.imageshack.us/img185/9319/wakeupcg9.jpg
                      • K Offline
                        kwistenbiebel
                        That's another great one again you did there 'Pixar guy' 😄
                        I hope you will make a little 'step by step' Poser tutorial one day.
                        Some time ago I tried Poser but had to give up as I could only get rubbish out of it.
                        Great work!
                        By the way,
                        If you really nag to JoeB of asgvis forum to get your license prolongued, you might get a another month of practicing time. I did the same and got it 😄
                        Asgvis (VrayforSU) considers it as good marketing to let people post as much as they can in their gallery. A policy I like 😄
                        • soloS Offline
                          solo
                          Put a good word in for me.
                          With the amount of inspiring work you are pumping out with just a trial he should give it to you for marketing purposes.
                          Your work is attracting customers, heck even I am tempted to buy the friggin thing and hound you for setup hints.
                          • soloS Offline
                            solo
                            An old model, from my 'bikini bottom' set. I wanted to see how Vue handled this.
                            http://img503.imageshack.us/img503/7421/krabnd8.jpg
                            The models are SU, however I used Vue's terrain.
                            • soloS Offline
                              solo
                              Another one, done with lowest quality, will try render it with GI some time soon, when i have a ka-jillion hours to waste.
                              http://img88.imageshack.us/img88/719/kitchjesasyz5.jpg
                              Everything except human figure modelled in SU, model is Poser, and rendered with Vue 5 inf.
                              • soloS Offline
                                solo
                                http://video.google.com/videoplay?docid=3602125257828359428&hl=en
                                • K Offline
                                  kwistenbiebel
                                  Solo, I just see a white square....
                                  I must be going snowblind 😄
                                  (Imageshack issue?)
                                  • boofredlayB Offline
                                    boofredlay
                                    I can see it fine.
                                    Nice.
                                      Ah, that was the "no render needed" or what topic's building, right?
                                      Really nice (although you must have done something to it finally).
                                      To me (maybe just because the sun is now shining onto my screen) it is a bit dark so I could not get many details.
