    SU2KT 3.0 Released
    12 Posts 11 Posters 1.4k Views 11 Watching
      tomasz
      Dear Sketchupers,
      I have released SU2KT 3.0.
      You can find description of new features and video ❗ tutorials by Fletch here
      and download it here.
      If you have account at KT Forum please post comments there if not please do not hesitate to do it here πŸ˜„
      Tomasz
      • FrederikF Offline
        Frederik
        Hi All,
        The new SU2KT version 3.0 has been released! πŸ˜„
        Credit for this new excellent integration with Google SU goes to Tomasz Marek...
        List of bug fixes and new features:
        • Memory leak bug fixed (SU2KT used to freeze on big scenes)
        • KT library materials import added - use KT Library materials inside SU
        • Back-face material exported when no front material specified or default (painted faces have priority over default material)
        • Optional Photo-matched faces\textures export (slower) as a selection or as exploded faces
        • Model opening in KT after export (Win only - so far)
        • Automatic animation rendering after path export (Win only - so far)
        • Wrong date bug and Time bug for non GMT locations fixed
        • Icons added for export options
        • Tools for placing spot & pointlights added
        • When KT material has no texture - SU2KT will use SU texture as a bump map
        • Correct Sun intensity when model opened automatically - otherwise please update Sun in KT Sun Wizard window
        • Sun animation will modify Sky as well - Download sample AVI (Xvid - 2,3MB)
        • Default UVs export option - for later texturing inside KT
        • Intensity of colours back to 1.0
        • Missing GIF textures bug fixed
        Fletch has prepared a bunch of three VIDEO Tutorials! Thanks a lot!
        Simple SU2KT Export example (7.9MB)
        Photomatch feature (4MB)
        KT Materials Import (10.3 MB)
        To download the new SU2KT, please visit the KT repository...
        Cheers
        Kim Frederik
        KT Team
        Cheers
        Kim Frederik
        • I Offline
          ilay7k
          Thanks! I will try!
          • ToboboT Offline
            Tobobo
            I cant wait to get this home!
            Thanks for all the hard work
            Toby
            Philippians 4:13
              Ben Ritter
              Thank you for all of your hard work and generosity.
              Ben
              • jujuJ Offline
                juju
                Looks like Christmas came early this year! Thx ppl!
                • W Offline
                  Will03
                  I cried a single tear when this came out, Thank you so much you guys! its perfect!
                    tomasz
                    Thank you! I am glad you find it useful.
                    I have forgotten about one small but useful feature:
                    • Importing KT materials works with selection. It will limit SU materials and allow you to attach KT mat only to those present in selection. It is a remedy when list of SU mats is too long.
                    Tomasz
                    • O Offline
                      oecodesignator
                      Hello Tomazc. haven't tried it yet but the potential to master it is delicious in itself. Plus, thanks for giving something that could level the field between high tech arm twisting intuitive, joyful design communication.
                      Your life will be one of eternal good karma.
                      Ain't it a grrrreat day!
                      RICO
                        dylan
                        Once the zip file is downloaded, where is it unzipped to?
                        I notice it contains the .rb for the plugin folder, the .skp lights which I have from the previous version (unless they have changed) and some images.
                        Am I correct in thinking this version has a toolbar in SU?
                        http://dmdarchitecture.co.uk/
                          Yes you are right; it does actually have a toolbar. Unzip everything under the Plugins folder. The toolbar images should be in a su2kt subfolder. Are they in this subfolder within the zip file?
                          • eevaE Offline
                            eeva
                            dylan, why don't you use the installer? it extracts the files in the right folders. just remember to delete the old exporter.
                            not only does it have a toolbar, after exporting, it asks you, if you want to open the file in kerkythea... πŸ‘ πŸ‘ πŸ‘
