    Asian Inspired Pool
    3 Posts 2 Posters 500 Views 2 Watching
      Stu
      A quick Kerkythea render with a straight SU Jpeg. export overlay to bring out the linework in the paving and the tile texture in the pool.
      http://www.landesign.com.au
        Roger
        Stu, how did you define the water material in KT? Was it a thin glass? What if any photoShop work did you do? How did you define the lights and sky?
        http://www.azcreative.com
          Stu
          Thanks Jim.
          Roger the water is a straight SU material. I had tried using TG_ but it wasn't coming out as I wanted. Instead I got the reflections in Kerky and then overlaid that image with the SU export [with the water deleted to expose the tiles and pool sides]. I used a warping brush in PhotoImpact to disturb the water a bit and used a 'gradual luminance' filter, again in PhotoImpact to add interest to the light.
          Stu
