π Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
Asian Inspired Pool
A quick Kerkythea render with a straight SU Jpeg. export overlay to bring out the linework in the paving and the tile texture in the pool.
Stu, how did you define the water material in KT? Was it a thin glass? What if any photoShop work did you do? How did you define the lights and sky?
Thanks Jim.
Roger the water is a straight SU material. I had tried using TG_ but it wasn't coming out as I wanted. Instead I got the reflections in Kerky and then overlaid that image with the SU export [with the water deleted to expose the tiles and pool sides]. I used a warping brush in PhotoImpact to disturb the water a bit and used a 'gradual luminance' filter, again in PhotoImpact to add interest to the light.
Stu
