    [Plugin] PronButton
    3 Posts 2 Posters 5.3k Views 2 Watching
    • A
      azuby
      OK guys, a PronButton for Sketchup. You can implement getStringFromObj() on your own šŸ˜‰
      On the other hand you can use this one to memorize things while working. Put some images to the pronbutton/img directory, that's it. It does not run automatically, because I do not want to maybe break a difficult manipulation you are doing to your model, i.e. Shift+select lots of faces.
      Download: http://www.errorinitus.de/ > Software > PronButton
      azuby
      • jujuJ
        juju
        I ask myself... "why?". Please sketch a scenario where this script would be of use, so I may better understand what this script does, your site describes even less than here. Many thanks.
        • A
          azuby
          It was intended to be a fun script for distraction: Click the button, a full screen window will open and show one of the images from the img directory, i.e. the "getStringFromObj()" image. But in the German subforum I got the idea to go on developing it with the intent to have fast acces to model relevant images (ground plans and so on).
          azuby
