    Divide with construction points
    4 Posts 4 Posters 822 Views 4 Watching
    • Didier BurD Offline
      Didier Bur
      Hi all,
      Incidentally I had to write this little tool. It is similar to the "divide" command of Autocad, which doesn't break a line or segment into parts but insert points along a line, given the number of segments.
      USAGE: Pick an edge, right-click and select "Divide by construction points". Enter the number of segments.
      Download here:
      http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=5633
      DB
        Thanks Didier, this may indeed come handy!
          sketchy
          Thanks much Didier! I will use this one for sure. I also always appreciate your generosity.
          • jujuJ Offline
            juju
            Thx Didier!
