    Housebuilder question
    3 Posts 3 Posters 821 Views 3 Watching
    • B
      bcoleman001
      I just finished the frame of my house using housebuilder. Now I'm want to add a texture to the roof and siding. If I texture the skin that housebuilder created, then I can see the frames from the inside through the skin. What do you do to get around this? I've thought of either turning of the lines or possibly adding another "skin" to the plane and extrude it 1/2" or so in order to get a clean texture. Any thoughts?
        3eighty
        Let me see if I can get this correct..Please correct me if I'm wrong...First turn on the hidden layer..Pull the wall out with Push/Pull...Da-da. πŸ˜†
        • gullfoG
          gullfo
          i delete the skins layer thats generated and add my own coverings - drywall, plywood, insulation, etc... since its easier to control, split on layers, and apply materials individually so the cut sheet script will apportion things correctly (lumber vs sheet goods). otherwise - push-pull to adjust the size of each.
          it would be great to have a unified version for both metric and imperial as well as real covering layers for typical constructs or options to adjust - like exterior wall vs interior wall, size of drywall, insulation or not, exterior ply or not, etc... πŸ˜„
          Glenn
          http://www.runnel.com
