    Extrude lines along path
    11 Posts 5 Posters 5.5k Views 5 Watching
    • FletchF
      Fletch
      is there a ruby written somewhere that is basically a 'Follow Me' tool for lines?
      I would like to select lines as the path, then choose the 'FollowMeLines' tool, and then select the lines I want to follow along that path... and have it create the faces... would be handy for wrapping a fascia around the odd corner... or a million other things.
      I know how to do this in a million other ways... but that tool would rock, IMHO.
      Fletch
      3D Modeling addict. Former owner/developer of Twilight Render. sleepinggiantvisual.com
      • R
        remus
        i know didiers got a ruby that projects a line along a vector, not sure if it does it along a path though. The ruby's called projection.rb or something similar.
        • FletchF
          Fletch
          yes, but that only works with 2 point you click, right? or would if follow a path if they were lines that were glued together?
          Fletch
          • R
            remus
            your right, it only works with 2 points you specify, so wouldnt work for a curved line or a series of lines.
            • G
              gata
              It works on a curve(s) - they can even be distinct, separate entities. Select curve(s) > select script tool.
              It explodes polylines though so edges are not soft.
              • R
                remus
                i was talking about the vector which the line must follow, so although you can extrude curved lines, you canot extrude curved lines along a curved path, and as i understand it, this is what fletch is looking for.
                • FletchF
                  Fletch
                  correct Remus, I'm looking for something that works exactly like the followme tool... the part where you select the lines to follow first, then click the followme tool... then the face follows those lines you had selected previously... I'd like to do that, but just with a couple lines instead of having to close the face, then followme, then erase the thousand unwanted faces (if we are talking about following many many lines in one shot)
                  Fletch
                  • CadFatherC
                    CadFather
                    (sorry didn't read the whole post).. if i understand right you just need to draw the path on the floor, select it and use Didier's project/extrude lines. it will be like the follow me tool, only done the opposite way..
                    • G
                      gata
                      On a 3D path, FollowMe twists. The normal direction keeps changing. A line version would fight the same issues.
                      Al Hart had some success keeping a face properly oriented in his flat path extrusion tool. But there were some problems with some types of paths. So the tool is still in beta.
                      • FletchF
                        Fletch
                        thanks guys...
                        ok, I am maybe using the wrong script, because it's not working as described.
                        I downloaded and used the projection_extension.rb. I followed the tutorial .pdf provided (Great work, Didier!)... but it does not do this... see attached image. for simple example
                        concept for a took called 'FollowMeToolForLines' or 'ExtrudeLinesAlongPath' (because 'FollowMe' is probably a protected name)
                        Fletch
                          http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/ExtrudeAlongPath.rb ?
                          Not exactly but...
