    "Bend" Distortion
    3 Posts 3 Posters 869 Views 3 Watching
    • JClementsJ Offline
      JClements
      Fredo6:
      Do you have anything like this in your bag of tricks. It would take geometry and "bend" it.
      This example isn't very good because I only rotated a few hidden sections, it should look like a smooth, non-segmented "trunk". Also this is only "bent" along the blue axis plane. Could a more complex distortion, for example, along the blue and then the green axis plane be done as you might see in the trunk of a palm tree?
      • fredo6F Offline
        fredo6
        I have this one in preparation, for a composite model (i.e. any drawing elements, groups, etc... with texture transfer, etc...) and a curve in 3D space.
        Actually, the main difficulty is about managing some topological cases where it is necessary to remove and cut faces that are squizzed in the curvature.
        • 3 Offline
          3eighty
          JC> Go to this link and pickup this FREE program..It has a Fantastic "bend" function..
          http://www.cbmodelpro.com/forum.html ...(You may have to type it in as I can't seem to get links to work..) 👍
          Richard
