    .aerosol can.
    30 Posts 11 Posters 3.0k Views 11 Watching
    • marked001M Offline
      marked001
      i know... aerosol can...(i know..woohoo.. so exciting) this is a WIP that i started yesterday for a client..not really sure what its going to be used for..he does alot of instructional stuff i think.. i modelled this off of a spray paint can..but apparently its supposed to look like a can of bug spray... so i wasted a little time.. ultimately, every single piece of this can will be hotlinked..either in html or flash.. but anyway..here it is so far.. made this super super high poly since i wasnt sure if it was going to be rendered or not.. sooo sloww... 100 segment circles 😕
      http://img481.imageshack.us/img481/6262/aerosolcanv1080607hb8.jpg
      http://img481.imageshack.us/img481/5215/aerosolcanv2080607kb1.jpg
      http://www.revision21vis.com
      instagram: revi21on
        cheffey
        gotta love high-poly!
        BROS RŌMAN BRÄUN
          Yeah, I know that. Once I made a 90 something segment arc to be a guide for a radial array of bricks in an arch. It was a pain...
          Nice can though!
            CADken
            OooOOOOoooooOOOO!
            nice!
            "it seems like everything I do is a work in progress..."
            • I Offline
              ilay7k
              It's nice!
              And i try to model it
              Render in sunflow
              If you need to see - http://rapidshare.com/files/47561588/banka.zip
                cheffey
                ilay7k,
                that spray nozzle looks kind of small on there.
                BROS RŌMAN BRÄUN
                • I Offline
                  ilay7k
                  Thanks!
                  It's just speed-modelling(2-3 min.)
                  I will re-work it
                    cheffey
                    you could probably just scale it.
                    back to the original thread...
                    Jason, how are you guys going to hot-link this thing?
                    BROS RŌMAN BRÄUN
                      marked001
                      haha..i wish i coudl go that fast..but it needs to be reasonably accurate..so i'm sitting here measuring a damn can..haha.. just went out and bought the specific can that it is, and started over.. unfortunately, follow me is not cooperating..and when i extrude it around the circle..some planes and arcs get left out.. i've tried it a million different ways and have redrawn it..but still the same thing.. i think i'm going to steal the top piece off my original can though..b/c this is frustrating.. the missing areas arent too evident here, but i think they ultimately will be 😕 here is the progress so far...there are a TON of little pieces on a damn spray can that i have to call out..i had no idea.
                      http://img266.imageshack.us/img266/9624/aerosolcanv1080707mj4.jpg
                      as far as hotlinking.. haha.i dont know.. either html or flash.. and just make a bunch of buttons over the image? that's my plan anyway..
                      instagram: revi21on
                      • KrisidiousK Offline
                        Krisidious
                        great stuff Mark, very life like...
                        ilay7k , your dome is a little high and I agree your nozel is a little small, but fine work none the less... I also liked your rendering nice material...
                        Mark, I really like that new lid or top... looks like RAID!
                        keep it up kids...
                        By: Kristoff Rand
                          cheffey
                          ok, i got you then.
                          it looks very good though, especially with the can top.
                          BROS RŌMAN BRÄUN
                            cheffey
                            i guess i'm with you Jason, except i probably take a bit longer to model things than you. i get bogged down with the dimensions so much sometimes... 2-3 minutes to model that is very fast to me. i wish i had that efficiency.
                            BROS RŌMAN BRÄUN
                              marked001
                              yeah.. 2-3 minutes is definitely impressive.. 5 minutes and it would've been great!
                              glad someone else is on the slow side though, steven..haha.
                              instagram: revi21on
                                cheffey
                                Hey, i know... it's like if i could only get out of my own way i could model faster.
                                i'll fumble around with 64ths of an inch.
                                that's crazy isn't it... 😳
                                probably shouldn't have said that.
                                BROS RŌMAN BRÄUN
                                  smartsizer
                                  try scaling your entire model up by a factor of 100. That might fix your follow-me problems.
                                    marked001
                                    ah ok.. that does make sense.. the original one i did was scaled up 10x just to make drawing the curves easier...this one was only 2x.. i will give that a try! thanks!
                                    instagram: revi21on
                                      marked001
                                      taht worked great smartsizer..thanks so much.
                                      here's a little update..
                                      http://img299.imageshack.us/img299/7225/aerosolcanv1080807ha7.jpg
                                      http://img299.imageshack.us/img299/4044/aerosolcanv2080807vr6.jpg
                                      instagram: revi21on
                                        todd burch
                                        Loosk great! My only comment is the bottom stem of the spray tip is too narrow in diameter.
                                        This looks great! I like the section cuts.
                                        Got a close up of how the pressure valve works? I've always wondered... I figured the refrigerator light thing out a few years back - but the aerosol tip pushing down thing I still haven't worked out. Wink
                                        Any now for the trivia question - and don't search the internet for the answer.
                                        "RAID" used a particular artist for a particular reason when they commisioned their bugs in the TV commercials. Who was the artist, and what was characteristic about his/her style?
                                        Todd
                                          cheffey
                                          that aerosol can is pimp... are we allowed to use that as an adjective?
                                          anyways it's marvelous.
                                          got nothing on the trivia question...
                                          BROS RŌMAN BRÄUN
                                            marked001
                                            http://www.aboutaerosols.com/packaging_valve.php
                                            there's my reference..not that i followed it too carefully..haha..
                                            and i have no answer for the trivia question..haha.. 😳
                                            instagram: revi21on
                                            • 1 / 2
