    .aerosol can.
    30 Posts 11 Posters 4.5k Views 11 Watching
    • marked001M
      marked001
      i know... aerosol can...(i know..woohoo.. so exciting) this is a WIP that i started yesterday for a client..not really sure what its going to be used for..he does alot of instructional stuff i think.. i modelled this off of a spray paint can..but apparently its supposed to look like a can of bug spray... so i wasted a little time.. ultimately, every single piece of this can will be hotlinked..either in html or flash.. but anyway..here it is so far.. made this super super high poly since i wasnt sure if it was going to be rendered or not.. sooo sloww... 100 segment circles 😕
      http://img481.imageshack.us/img481/6262/aerosolcanv1080607hb8.jpg
      http://img481.imageshack.us/img481/5215/aerosolcanv2080607kb1.jpg
      http://www.revision21vis.com
      instagram: revi21on
      • C
        cheffey
        gotta love high-poly!
        BROS RŌMAN BRÄUN
        • GaieusG
          Yeah, I know that. Once I made a 90 something segment arc to be a guide for a radial array of bricks in an arch. It was a pain...
          Nice can though!
          • C
            CADken
            OooOOOOoooooOOOO!
            nice!
            "it seems like everything I do is a work in progress..."
            • I
              ilay7k
              It's nice!
              And i try to model it
              Render in sunflow
              If you need to see - http://rapidshare.com/files/47561588/banka.zip
              • C
                cheffey
                ilay7k,
                that spray nozzle looks kind of small on there.
                BROS RŌMAN BRÄUN
                • I
                  ilay7k
                  It's just speed-modelling(2-3 min.)
                  I will re-work it
                  • C
                    cheffey
                    you could probably just scale it.
                    back to the original thread...
                    Jason, how are you guys going to hot-link this thing?
                    BROS RŌMAN BRÄUN
                    • marked001M
                      marked001
                      haha..i wish i coudl go that fast..but it needs to be reasonably accurate..so i'm sitting here measuring a damn can..haha.. just went out and bought the specific can that it is, and started over.. unfortunately, follow me is not cooperating..and when i extrude it around the circle..some planes and arcs get left out.. i've tried it a million different ways and have redrawn it..but still the same thing.. i think i'm going to steal the top piece off my original can though..b/c this is frustrating.. the missing areas arent too evident here, but i think they ultimately will be 😕 here is the progress so far...there are a TON of little pieces on a damn spray can that i have to call out..i had no idea.
                      http://img266.imageshack.us/img266/9624/aerosolcanv1080707mj4.jpg
                      as far as hotlinking.. haha.i dont know.. either html or flash.. and just make a bunch of buttons over the image? that's my plan anyway..
                      instagram: revi21on
                      • KrisidiousK
                        Krisidious
                        great stuff Mark, very life like...
                        ilay7k , your dome is a little high and I agree your nozel is a little small, but fine work none the less... I also liked your rendering nice material...
                        Mark, I really like that new lid or top... looks like RAID!
                        keep it up kids...
                        By: Kristoff Rand
                        • C
                          cheffey
                          ok, i got you then.
                          it looks very good though, especially with the can top.
                          BROS RŌMAN BRÄUN
                          • C
                            cheffey
                            i guess i'm with you Jason, except i probably take a bit longer to model things than you. i get bogged down with the dimensions so much sometimes... 2-3 minutes to model that is very fast to me. i wish i had that efficiency.
                            BROS RŌMAN BRÄUN
                            • marked001M
                              marked001
                              yeah.. 2-3 minutes is definitely impressive.. 5 minutes and it would've been great!
                              glad someone else is on the slow side though, steven..haha.
                              instagram: revi21on
                              • C
                                cheffey
                                Hey, i know... it's like if i could only get out of my own way i could model faster.
                                i'll fumble around with 64ths of an inch.
                                that's crazy isn't it... 😳
                                probably shouldn't have said that.
                                BROS RŌMAN BRÄUN
                                  smartsizer
                                  try scaling your entire model up by a factor of 100. That might fix your follow-me problems.
                                  • marked001M
                                    marked001
                                    ah ok.. that does make sense.. the original one i did was scaled up 10x just to make drawing the curves easier...this one was only 2x.. i will give that a try! thanks!
                                    instagram: revi21on
                                    • marked001M
                                      marked001
                                      taht worked great smartsizer..thanks so much.
                                      here's a little update..
                                      http://img299.imageshack.us/img299/7225/aerosolcanv1080807ha7.jpg
                                      http://img299.imageshack.us/img299/4044/aerosolcanv2080807vr6.jpg
                                      instagram: revi21on
                                      • T
                                        todd burch
                                        Loosk great! My only comment is the bottom stem of the spray tip is too narrow in diameter.
                                        This looks great! I like the section cuts.
                                        Got a close up of how the pressure valve works? I've always wondered... I figured the refrigerator light thing out a few years back - but the aerosol tip pushing down thing I still haven't worked out. Wink
                                        Any now for the trivia question - and don't search the internet for the answer.
                                        "RAID" used a particular artist for a particular reason when they commisioned their bugs in the TV commercials. Who was the artist, and what was characteristic about his/her style?
                                        Todd
                                        • C
                                          cheffey
                                          that aerosol can is pimp... are we allowed to use that as an adjective?
                                          anyways it's marvelous.
                                          got nothing on the trivia question...
                                          BROS RŌMAN BRÄUN
                                          • marked001M
                                            marked001
                                            http://www.aboutaerosols.com/packaging_valve.php
                                            there's my reference..not that i followed it too carefully..haha..
                                            and i have no answer for the trivia question..haha.. 😳
                                            instagram: revi21on
