    [Plugin] CurrentDate 0.4
    1 Posts 1 Posters 3.4k Views 1 Watching
    • A
      azuby
      CurrentDate got an update 💚
      You now can let the Plugin doing the job of clicking the menu entry for update the values in the Shadow dialog. For that you can specify a refresh rate.
      Please keep in mind that Ruby uses green threads. I've made the experience, that CurrentDate will only update the settings, if you use Sketchup - by moving the mouse and so on.
      Navigate to http://www.errorinitus.de/ > Software > CurrentDate
      Hope, it helps,
      azuby
