    Bowfront Table with exploded view
    4 Posts 2 Posters 767 Views 2 Watching
      Sawduster
      The main reason I got involved with Sketchup was to help in my woodworking hobby. I seldom use other folks' plans for stuff, generally building from either an idea in my head or from a picture from a magazine or advertisement with some overall dimensions.
      In the process of learning Sketchup, I've designed a few simple furniture pieces, some of which I had built previously, others that I may build at some time. This bowfront table is similar to one I made some time back, though I didn't use cabriole legs on that one.
      The Sketchup file contains several scenes, some of the overall table, then an exploded view showing the joinery used, and finally a profile of the cabriole leg which could be used to create a full sized pattern if one were wishing to do so. I've not included any dimensions, though someone could add those themselves using the dimension tool. My method of work is to start with overall dimensions for major parts, then fit the remaining pieces individually. I find this method works best for me as wood has a tendency to "move" when the weather changes. Since woodworking is seldom done to tolerances of less than 1/64th inch, a measurement clearly visible to the human eye, small errors, even 1/128th inch, seem to aggregate rather than cancel each other out, so marking pieces directly from the pieces then are meant to house etc. works better for me than just cutting things to dimensions on a drawing.
      Anyway, here's a jpg of the table and a link to the sketchup file.
      http://www.sawdustersplace.com/Sketchup files/BowTable.jpg
      http://www.sawdustersplace.com/Sketchup%20files/BowTable.skp
      May all your dimensions be the sum of their total.
      Jerry
        alan wood
        Hi Sawduster,
        I love the very clear way you have illustrated how this piece of furniture is made. Also enjoyed visiting your web site and will have a good read later when I have more time.
        I noticed your dovetail templates and marking knives. I dont know if you have seen my posting on the jewellery box but I have posted the dovetail templates and knives I use which you may find of use.
        thanks for posting
        Alan
        πŸ˜† πŸ˜† πŸ˜† πŸ˜†
          Sawduster
          Alan,
          Thanks for the compliments. Went and too a look at your post with the DT templates and knives. Like the idea of altering that utility knife blade to work better as a marking knife, and the DT templates are cool too. I've got a soft spot in the heart for layout and marking tools. πŸ˜„
          Jerry
            alan wood
            Hi Sawduster,
            I noticed another posting of your on this site and its interesting to see the Fine Woodworking are now using sketchup.
            I think its a great idea.
            cheers
            Alan.
