    Help with an avatar
    7 Posts 4 Posters 412 Views 4 Watching
      trs
      I'm trying to create an avatar. I have Photoshop Elements and Picasa 2. Problem is I can get the re size down to the legal limit. Help please.
      trs
        todamgood4U
        If you want, you can send me the image and I will resize and send it back.
          trs
          Thanks, but I was hoping to learn something here.
          trs
            todamgood4U
            Ok, well I don't have either of those programs, but if Elements is anything like photoshop, you should be able to crop the image with the marqee tool and then image/crop, or the crop tool. Resizing should be as easy as going into image/image size and putting in a width/height. From there, you can save it down to .jpg or even .gif if it's not a photo. If it has a "save for web" like photoshop, use that and pick the 4 views. Pick the one that is smallest and looks best.
            Sorry I couldn't be of more help.
              tomsdesk
              Shaun turned me on to Easy Thumbnails...works like a dream:
              http://www.fookes.com
              2.5D Trees & Shrubs!
                JuanV.Soler
                what i did was to import the image to sketchup and then saved as jpg. in the window of saving there´s an adjust for the pixel´s size.
                  trs
                  %(#80BF40)[Thanks to all, once I turned on "resample image" in Photoshop, it then allowed me to edit the pixel size of the image.
                  Now I can play "fun with avatar's".
                  trs]
