    Exterior panorama
    43 Posts 15 Posters 5.9k Views 15 Watching
      l_verio
      Hi !
      I made the "hungarian example" Gaieus mentiOned above ...
      I'm using a mac,
      and downloaded your panorama from the link at the beginning.
      WORKS PERFECTLY FOR ME :S
      • O Offline
        otb designworks
        Thanks for the update.
        I am glad to hear that it worked for you. Apparently, there is some sort of a bug with image exif data. As should come as no surprise, it works on a Mac but PC doesn't work.
        Cheers, Chuck
        OTB Designworks is on Youtube
          TriciaS
          Hi Chuck,
          I think I may know what is going on with this issue. I believe your images have an exif (common to digital cameras) format - true? If so, we have finally isolated a bug with exif formatted images. Those images can display correctly on the Mac but fail to display on the PC. Unfortunately, the only workaround that I have found is to save the images with a different format. We are working on this issue though.
          Does that help?
          Best regards,
          Tricia
          • 3 / 3
