    Green Toaster's Car Sketches
    745 Posts 45 Posters 200.4k Views 45 Watching
      GreenToaster
      Look at the lack of details in this shape - I purposely "chiseled" out just a few corners here and there, stuck on a grill and . . . a six hundred second car . . .
      If you really want something you won't ever stop pursuing it.
        What a productivity! πŸ‘
        Take care, put your Savety belt! πŸ˜‰
          GreenToaster
          . . . another GreenToaster cookie cutter car body shape . . . (yawn) . . . fairly dull but very quickly modeled . . .
            GreenToaster
            . . . another quick sketch . . . I'm trying to figure out when it's best to add certain types of details, like the scoop in the nose . . . after smoothing, or before ? . . . hmmmmm . . .
              GreenToaster
              . . . trying for something just a wee bit more exciting than the last one . . .
                GreenToaster
                . . . sometimes you have to try new things . . . this obviously didn't work out as the transition didn't turn out the way I wanted . . . still a great learning experience - AND - as a bonus, I tried something new w/the top and discovered a great way to get the top done without using the SketchyFFD script (not that there's anything wrong with either that script or using it to define geometry).
                  GreenToaster
                  . . . and, if I can figure out how to use my version of Camtasia, I'll do a tutorial for the top . . . really easy schmeezy and super quick technique that provides lots of flexibility with shaping . . . or maybe I'll do an animated gif w/text like the other tutorial I did several weeks ago . . .
                  Happy Sketching,
                  Brad
                  πŸ˜„
                    GreenToaster
                    . . . it really must be time to take a break . . . things are getting uglier by the minute . . . this one looks much better when you step away from the computer screen (far away), remove your glasses, and then squint so you can hardly see anything . . . even then, it's still not a very pretty sight . . . oh well, there's always tomorrow, right?
                    Happy Sketching,
                    Brad
                    πŸ˜„
                      GreenToaster
                      . . . added some fender wells to this one - 2 1/2 degrees rotated from vertical . . . I sort of like the nose on this one . . .
                        GreenToaster
                        . . . slipping into the "boring" mode again . . . another fairly bland vehicle . . . next one will be exciting . . . I promise . . .
                          GreenToaster
                          . . . I don't like the technique I used for this one but hey, for a five minute car, what do you expect . . . at least it's a little more "exciting" or sporty than the last one . . .
                            CADken
                            well, here is a quick post to show off what I've been working on, purely off blueprints, intersecting shapes and what have you... I tried to create a mapped layer to shape the body (kind of like in 3Ds Max) but I found it much easier to tweak solids and such...
                            here's my Fire Engine (WIP):
                            http://i90.photobucket.com/albums/k242/KensNikonL3/windowswheels.jpg
                            i'm liking your various models tho, keep it up! πŸ‘
                            "it seems like everything I do is a work in progress..."
                              GreenToaster
                              Nice truck - I like it!
                              Here's another experiment - I'm not taking many chances with this idea, just something a little different in a couple of areas.
                              Happy Sketching,
                              Brad
                              πŸ˜„
                                GreenToaster
                                . . . another slight variation on the same theme . . . (yawn) . . .
                                  GreenToaster
                                  . . . C4T . . . didn't do the back or wheel well areas . . . maybe later . . .
                                    GreenToaster
                                    . . . and another very quick one . . . again, same theme . . . nothing drastic or new . . .
                                      GreenToaster
                                      . . . something a wee bit different . . . ultra-quick sketch of a car - a vaguely inspired version of an Audi A2 (if you really use your imagination you might see a slight resemblance) . . .
                                      Happy Sketching,
                                      Brad
                                      πŸ˜„
                                        GreenToaster
                                        . . . another bland silly-quick what if . . .
                                          Bob C.
                                          Brad,
                                          I would love to see your tutorial for the top done in Camtasia, please!
                                          Bob C.
                                            GreenToaster
                                            Bob,
                                            I have a copy of Camtasia but I've never used it. I will try to see where it is and then find out what I can do with it - the animated gif tutorials I've done thus far aren't very good.
                                            Happy Sketching,
                                            Brad
                                            πŸ˜„
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 37
                                            • 38
                                            • 17 / 38
