    How do I eliminate this banded effect in a tileable texture?
    6 Posts 4 Posters 1.2k Views 4 Watching
    • P
      pichuneke
      I would like to do it using free software, like gimp (if possible). I have searched in Google for a solution, but I had no luck.
      This is the effect:
      http://i29.tinypic.com/16azarm.jpg
      I am not good with gimp or similar software, but I have to make a good stone texture and I know that is very important for the finished model.
      Thanks.
      Forgive my spanglish...
      • P
        pichuneke
        I have made a first attempt. In fact I was looking for a way of doing it with a script or something similar, but I see I have to do it manually. Anyway thanks Alan.
        I have to go out for three days, so I won't be able to respond you untill thursday. If you have another way to fix the problem, let me know 😉
        • Alan FraserA
          Alan Fraser
          It looks like one corner of the original image is a little darker than the rest of it. You will need to use a Dodge tool (I don't know what it is called in Gimp, but it is usually Dodge in every other image editor.) If it has a soft brush setting, use that until you lighten the corner enough, so that it does not form those dark bands when repeated. You may need to try it a few times and then re-tile the image until it looks OK.
          3D Figures
          • jujuJ
            juju
            You could try any of the following apps:
            • Seamless Texture Generator Pro: automates the process of getting lighting levels correct on the texture to be generated, can also tweak the levels yourself.
            • Genetica: I have not used it myself, however I understand it is quite good.
            • P
              pichuneke
              I used only Gimp, as I like to use opensource/ free software. This is a better version, using the dodge tool. There are some glitches yet, but I am happy with this at the moment.
              http://i26.tinypic.com/2mh7dcw.jpg
                Jim
                This tutorial shows a technique that may help eliminating shading.
                HOME : RICARDO A. MUÑOZ
                (www.bitbrush.com)
