    Copytopath
    3 Posts 3 Posters 771 Views 3 Watching
    • V Offline
      Verrou
      Well there's no forum for general plugins so i'll just post it here.
      My copytopath tool is broken, or at least i think it is -.- When i click copytospacing, then the line, then the shape, the shape is rotated and enlarged? So when i make a line of dominoes instead of a line, they are side by side and double in size -.-
      Any help?
        Verrou,
        To make sure you get the right answer, I moved your question to the Ruby Discussions.
          RickW
          Is this regarding the PathCopy script from Smustard?
          If so, I suspect that you have scaled the items you are trying to copy. If it's a component instance, PathCopy uses the definition and inserts new instances along the path. This would explain the change in scale. Also, the script uses the component axes for the initial placement along the path. So, you may need to redefine your component's axes, or inside the component rotate the geometry at the component's origin.
          There are a few issues that I have on my list to update for PathCopy, but time is short...
          RickW
          [www.smustard.com](http://www.smustard.com)
