    2D software
    34 Posts 16 Posters 7.1k Views 16 Watching
      anglaret
      Hello
      Thanks for the comments, there are some that I do know, such datacad,Qcad which are powerful, but too complicated from my purpose (electronic drawing table is not what I seek for).
      I join an example of a look that I would like to have: Don't say I have it, because 3D architect 2008 is a ache to move walls, connections don't follow, impossible to draw the right length directly, you have to re-place the wall+ the 2 connected walls, no ortho contraint.
      For me associated to SU that kind of soft which would have automatic walls, windows... would be the top, to give very quickly the idea of a project to somebody.
      I will try litecad, which seems very fluent, and to the others too
      Marc, architecte
      • L
        linea
        Try DraftIT Architectural. £99
        Not Found
        (www.cadlogic.com)
        Free version of this too, but it looks a bit too basic.
          alpro
          You should really take a look at Cadsoft Envisioneer then. Walls, floors, roofs are all automatic. Windows, doors, openings all cut in walls. Almost as easy as SU to learn and use. There is a 30 day demo available.
          Mike
          • BepB
            Bep
            Try Turbocad ,i am working with the pro 11 version at this time its about $50,- now.
            Version 14 is already out.
            It has a very helpfull user forum,its easy to learn ,yet it has great potential.
            Greetings,
            Bep van Malde
            "History is written by the winners"
            • P
              PeterCharles
              Have you checked out this? It talks about parametric relationships to maintain design intent.
              I would try it but I run Win2K at home, says it needs XP.
              ERROR: The request could not be satisfied
              (www.plm.automation.siemens.com)
              • C
                cdubea
                "In addition to a plethora of other CAD tools I use (SolidWorks, Sketchup, IntelliCAD, etc) I keep a copy of LiteCAD on a thumbdrive."
                Don’t mean to hijack this thread, but a portable version of SketchUp Pro would be nice.
                Ken
                It's never going to happen in a direct manner. The Sketchup EULA prevents anyone else from distributing Sketchup. The best you are going to get is a framework published that a user can use to create his own portable Sketchup version.
                I've been running Sketchup from a thumbdrive for about a month now. I use a batch files which write the appropriate info to the registry on startup and then delete the registry hives on quitting. The downside is the drive letters are hard coded so this is definitely not portable (I only use it on one machine).
                I've looked at the methods used to 'portablize' applications on http://www.portableapps.com and it's pretty simple. I just haven't had time to sit down and create the framework. I will, but I honestly don't know if I can share it 😐
                Take care
                chris
                http://www.dubea.org/chris_small.jpg
                  anglaret
                  Hello
                  I am having great difficulty to find a simple and expressive 2d cad. The best direction I have at the moment are Express envisioneer, and IMSI floorplan 3d.
                  But they all lack the SU touch which define keys and automatism right where thay have to be
                  • 3d architect have quite a look, but trimmings and dimensionnings are very bad
                  • cadsoft 2d is better on the 2nd point but adjusting is bad too, and there is a trigonometric obligation to design connected walls.
                  I am still doing my plans with SU; it is a pity that conversation seems broken with SU people, because I should have tried to be very convincing for a 2d adaptation.
                  Marc
                    alpro
                    The full version of Envisioneer has customizable short cut keys and several other ways to make it suit your needs. You can either model in model space or import your SU model into model space and then just insert your 2D views in paper space and do any editing that you need too. Also if you already have autocad blocks, you can import those as well. I've been using Envisioneer for a little over a year, I definitely think its the second easiest program to use, SU being first. Try the full version demo.
                    Mike
                      anglaret
                      Hello Alpro
                      I am OK with you that envisionner is a little instinctive, and I discovered that IMSI has exactly cadsoft envisionner engine, but the result is hard to obtain, and really poor in 2D, and bad in 3D
                      I feel that no company is interested with 2d, they all go like cannonball to 3D, so they neglect 2D. One example is the impossibility of reaching the centimeter precision with any of them.
                      In that search, I become very humble with the small imperfections of SU. SU is a wonderful machine, built with precision, intelligence and huge concern of the end user.
                      Marc
                      • L
                        linea
                        Strictly speaking, IMSI Floorplan isn't a cad program, it is a home decor program and not designed for accuracy. Autocad and traditional apps of that level may not be as easy or quick (or cheap) but the basic 2d tools that they still feature (alongside all the other new stuff) are IMHO still hard to beat in terms of flexibility. I do agree though, it does seem that there isn't any new thinking in terms of middleweight 2d, probably this is because the roll out of BIM software such as Revit automates the workflow from 2d to 3d or 3d to 2d.
                        Maybe we should make some suggestions to the Archimedes - open source cad project team. They are building a free architectural cad app for commercial use. http://archimedes.incubadora.fapesp.br/portal/project/archimedes-project/
                        • sketch3d.deS
                          sketch3d.de
                          as already mentioned above, DraftBoard Pro does have the ease-of-use as well as the precision (and automatically trimming/intersecting walls) you are looking for.
                          jm2c,
                          Norbert
                            alpro
                            anglaret, I've never had a problem with the percision of Envisioneer, you can set up the program to be as precise as you want. See attached, also some 2D plans done by another Envisioneer user (Ed Stalens) just to show that Envisioneer is more than capable of producing precise working drawings and does so rather quickly.
                            Mike
                            Edit, would only let me post three attachments but you should get the idea
                            • P
                              PeterCharles
                              Interesting as I've just read this....
                              upFront.eZine
                              the business of cad, enlightened
                              Issue #550 | March 11, 2008 | English Edition
                              Autodesk wishes it wouldn't but AutoCAD LT continues to outsell everything else, with sales up 33%. Seems there is quite a market for sub-$1000 CAD software.
                              • Mike LuceyM
                                Mike Lucey
                                SmartSketch, little know but good!
                                http://www.intergraph.com/smartsketch/
                                Mike
                                  anglaret
                                  It seems my answer has ben thrown out of the topic
                                  Here is a little analysis of my unseccessful search yet
                                  (note/10)-- soft-- editor --comment
                                  wall and partition dynamic components
                                  (4)-- Turbo Floorplan 3d-- imsi-- nice to use, bad 2d look
                                  (3,5)-- 3D architecte classic 2008-- arcon-- good result but hard to draw
                                  (3,5)-- chief architect
                                  (2)-- 2d softcad-- softcad-- intelligent but hard to use
                                  (2)-- envisionner-- softcad --same engine than floorplan but limited
                                  (2) --home design-- punch-- not adapted for 2d plans
                                  designworkshop -- 3d
                                  smartdraw-- poor look
                                  home plan pro -- not enough
                                  ez architect -- not enough
                                  electronic drawing board
                                  allplan
                                  arc+
                                  bentley
                                  datacad
                                  draft-it * draftboard
                                  graphisoft
                                  litecad very nice little tool
                                  progecad intellicad
                                  qcad
                                  solid edge - siemens
                                  turboacad
                                  I do not reach the same instinctive and pleasant contact that I love with SU
                                  Marc
                                  • GaieusG
                                    @anglaret said:
                                    It seems my answer has ben thrown out of the topic...
                                    Sorry Marc, It hasn't been thrown out but we had to restore a backup from the day before because of a serious problem that happened yesterday. You must have received Coen's PM about this.
                                    • L
                                      linea
                                      Envisioneer is distributed by Cadsoft. Softcad is a different company with three main cad programs; APC draft, Architech Pc, Softcad (2d and 3d version). I nominated Softcad in the worse ever software thread. IMHO the potential is there but the interface lets it down. There is a free version so hats off to them for generosity. However, they've not updated their site gallery for about ten years. That has to tell you something.
                                      http://www.envisioneer.co.uk/
                                      Not Found
                                      (www.softcad.com)
                                        anglaret
                                        Gaeius , thanks for care, it was no trouble at all;
                                        My above messages concerning a 2d soft makes me a lot less critical to SU
                                        Jon, sorry for mistaking softcad and cadsoft; I completely agree with your opinion about envisionner.
                                        For the moment I give up my present fever to find that 2D ; no doubt I will come back here if I find the answer
                                        Marc
                                        • G
                                          ginahoy
                                          I'd like to resurrect (but hopefully not hijack) this thread to ask a novice question.
                                          I'm looking for software to design my new home. I need to create construction drawings, like the ones posted above by Mike on March 10. What is it about SU that makes it less than ideal for 2D work?
                                          David
                                            anglaret
                                            ginahoye
                                            After my search, I am still doing my sketch drawings with SU
                                            Why?
                                            If SU is not very much good to design 2d, the use of textures , materials, components give a very nice look to present a 2d drawing
                                            Look at the attachment
                                            Marc
