    Looking for...
    10 Posts 2 Posters 2.1k Views 2 Watching
    • V Offline
      Verrou
      I'm looking for a tutorial that shows how to attach a pole to an arm that swings down and hit's a ball. Can't find many good SP tuts.
        CPhillips
        Make the pole and arm. Group them. Create a hinge joint. Attach pole/arm group to the hinge joint. Look on 3dwarehouse there are a ton of them.
        • V Offline
          Verrou
          Is it possible make something move forward automatically?
            CPhillips
            Not sure what you mean. Post a model and Ill show you how to add the physics.
            • V Offline
              Verrou
              Just say I have a cube, when I press play, I want it to more forward slowly.
              And, is it possible to freeze something until it hits a specific component?
                CPhillips
                Just attach it to a piston joint and change the settings until it is as slow as you want it.
                Not a specific object. Just any object.
                • V Offline
                  Verrou
                  How do you make freeze it until it hits a component?
                    CPhillips
                    Set its state to "frozen" in the UI.
                    • V Offline
                      Verrou
                      But it moves as soon as I click play, but I think it's because it starts with it touching it.
                        CPhillips
                        Dunno. Post the model and I'll take a look.
