    KT
    49 Posts 9 Posters 5.9k Views 9 Watching
    • david57D Offline
      david57
      Messed it up. Deleted parts of mullions on the right by mistake.
        kwistenbiebel
        Hi David,
        Looking better and better.
        A good ground texture will make this more alive.
        I like the crispness of the images so far. Keep those coming.
        • david57D Offline
          david57
          Thanks kwistenbiebel.
          Here's a ground view.
          • david57D Offline
            david57
            • david57D Offline
              david57
              Used KT's Instancing tool to populate a sphere with leaves.
                Really cool idea. and generally speaking, the plants give a nice extra to the images (although the treeline seems to be a bit flat and too roughly cutout)
                • david57D Offline
                  david57
                  A try at 8 spheres. The one to the far left, was my first test tree.
                  the leafs are to large and to sparce.
                    Nice hedges can also be created this way...
                    • david57D Offline
                      david57
                      Yes hedges and grass, but havent tried grass.
                      Working here on a deserted island, hopeing not, to see what's his name
                      walking through here, in his birthday suit.
                      • majidM Offline
                        majid
                        hi all /david .
                        i tried KT Brush over a bush i separately inserted and merged whit a leaf, and here is the draft render result , maybe it is good for mid-distance foliages . u may improve this idea using flowers ... bushes , trees ...or people ..
                        3rd test
                        • david57D Offline
                          david57
                          Tried Clipmaping of leafs, but couldn't get the right results.
                          • david57D Offline
                            david57
                            • david57D Offline
                              david57
                              Tree Trunk, Branches,and 10 Leafs were made with a Blender script called Gen3.
                              Made Components with Trunk, Branches, and only 10 Octagon Leafs in SU.
                              The same Ten Leafs were used for the Hedges, but smaller.
                              • david57D Offline
                                david57
                                Two more.
                                • david57D Offline
                                  david57
                                  Here,s another render.
                                  • david57D Offline
                                    david57
                                    Model in the background was not made by me.
                                    Model can be found at
                                    http://archidom.net/ddd/model_S.htm
                                    • david57D Offline
                                      david57
                                      Needs Pillars or Columns under the radius.
                                      • david57D Offline
                                        david57
                                        Trying to figure this one out, before a render. Need to remove the door ways
                                        on the first floor, they look like men and women restrooms.
                                        • david57D Offline
                                          david57
                                          • david57D Offline
                                            david57
                                            Here's a Progressive Path Tracing. I could'nt get rid of the arched door ways. I didnt
                                            have the guts.
                                            • 1 / 3
