    πŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    Sketchup.active_model.set_attribute
    12 Posts 3 Posters 985 Views 3 Watching
      Jorgensen
      I'm trying to keep track of some objects via "set_attribute"
      But when I retrive the objecs via "get_attribute" I get NIL 😞
      Is'nt possible to keep track of objects in set_attribute ?
      Jorgensen
      This is muy short test script:
      def tmTest
      model = Sketchup.active_model
      test = model.get_attribute "TM_area", "test", 'false'
      if(test == "false")
      test = Array.new
      a = model.selection
      for object in a
      test.push object.typename
      Sketchup.active_model.set_attribute "TM_area", "test", test
      for object in test
      puts object
        todd burch
        I've fixed a few errors. This is a complete test case that works.
        Todd
        def tmTest
        	test = model.get_attribute "TM_area", "test" ;
        	puts "test = #{test}" ;
        	if(test == "false")
        		test = Array.new
        	a = model.selection
        	for object in a
        	for object in test
        		puts object
        rc = Sketchup.active_model.set_attribute("TM_area", "test", "false") ;
        puts "rc = #{rc}" ;
        tmTest
          Jorgensen
          Thanks Todd
          Actualy, I need this to keep track of some add_text objects I create - so that I can run through the 'test' array and delete the objects that I have created, even if the file has been saved and Sketchup restarted. Will this be possible ?
          Is this right ?
          "rc = Sketchup.active_model.set_attribute("TM_area", "test", "false") ; "
          do you save the test array ?
          As you (and surely many others) can se, I'm not a programmer, just an architect, that have a need for a special function, and tries to create this by looking in others scripts and in this forum 😳
          Maybe there should be two groups under Ruby, one for programming ruby/sketchup and one for using plugins ?
          Jorgensen
            todd burch
            No, that doesn't save a test array at all. that saves a key of "test", and it's value" of "false".
            If you want to save an array worth of data, and then get it later, here is the code to do that:
            def save_array(data)
            	dictionary_name = "TM_area" ;
            	i = 1 ;
            	data.each {|value|
            		model.set_attribute(dictionary_name, "var"+i.to_s , value ) ;
            		i+= 1 ;
            end ;
            def get_array()
            	any_array = [] ;
            	i = 1 ;
            	while true
            		value = model.get_attribute(dictionary_name, "var"+i.to_s ) ;
            		break if !value
            		any_array.push(value)
            		i += 1 ;
            	return any_array ;
            end ;
            myarray = [] ;
            myarray.push("This is the first entry") ;
            myarray.push("Entry #2...") ;
            myarray.push("3rd and final entry.") ;
            save_array(myarray) ;
            myarray = []  ;   # reset array to empty
            myarray = get_array() ;
            i = 1 ;
            myarray.each {|value|
            	puts "Value #{i} is #{value}." ;
            	i+=1 ;
              Jorgensen
              Hi Todd
              Thanks for your input - it works well πŸ˜„
              I have one problem though:
              I use the get_array to recive an array (logic πŸ˜„ )
              I then run through this array - witch contains some entityIDs and if an object, with this ID exist, I delete it from the model and from the array. I then save the array again.
              The problem is, that even if I delete some keys from the Array - so lets say the original array has an length of 10 and I then delete five objects, the length of the array is 5. I then save the array - from i=1 to i=6 - but the old ones from 6-11 still exits in the dictionaryname - how do I delete the var1 - var10 before updating the dictionaryname ?
              Jorgensen
                Jorgensen
                I guess it could be solved via delete_key - but how ?
                  Jorgensen
                  I have just tried to save
                  model.set_attribute("TM_area", "objects", data)
                  where data is an array - I can close sketchup and open gain, reload the file and the array can be read again as model.get_attribute("TM_area", "objects")
                  Works fine - BUT
                  why the #€"#€%€%) have the entityID for the objects I created change when I reload the file ? now I can't keep track of them anymore 😞
                  a guite tired
                  Jorgensen
                    Jorgensen
                    I guess this has something to do with it
                    "The entityID is not persistent between sessions."
                    But how can I then recognise objects when a file is reloaded ?
                    Jorgensen
                      todd burch
                      I'm certain there is a delete method to get rid of a dictionary key. Before saving the array, delete all existing keys. It's a brainless (simple) way to do it.
                      How? Figure it out! Use the Ruby console to experiment. http://download.sketchup.com/sketchuphelp/gsu6_ruby/Docs/Ruby-AttributeDictionary.html#delete_key
                      You can't use entityID across SketchUp session. Assign them your own ID as a key/value. "Jorg1", "Jorg2", "Jorg_Cabinet", "Jorg_Oil_Platform", etc. Whatever you want to call them. Use some Dictionary name that you expect will be unique in the bog scheme of things. Perhaps a dictionary names like "Jorgensen" or something unique to you / about you. I use "Smustard".
                      Todd
                        Jorgensen
                        YES YES YES YES
                        I found the solution 😍
                        I add a entity.set_attribute ("TM_area", "TM_ID", "TM_ID " + target.entityID.to_s)
                        This is kept and can be used to recognise the objects - finally the script can be finshed 🀣
                        I won't disturb anymore - I did that quite alot - sorry
                        Thanks Todd (thanks all)
                        Jorgensen
                        Here it is in action. This will be very useful for me when sketching projects with focus on areas
                          CPhillips
                          @jorgensen said:
                          YES YES YES YES
                          Jorgensen
                          Be advised that entityID can change when a file is saved and loaded. I hope that isnt a problem for your application.
                            Jorgensen
                            That should not be a problem, because I'm adding my own attribute:
                            that I use to keep track of objects.
                            Jorgensen
