Sketchup.active_model.set_attribute
I'm trying to keep track of some objects via "set_attribute"
But when I retrive the objecs via "get_attribute" I get NILIs'nt possible to keep track of objects in set_attribute ?
JorgensenThis is muy short test script:
def tmTest
model = Sketchup.active_model
test = model.get_attribute "TM_area", "test", 'false'
if(test == "false")
test = Array.new
a = model.selection
for object in a
test.push object.typename
Sketchup.active_model.set_attribute "TM_area", "test", testfor object in test
puts object
end -
I've fixed a few errors. This is a complete test case that works.
Todd
def tmTest model = Sketchup.active_model test = model.get_attribute "TM_area", "test" ; puts "test = #{test}" ; if(test == "false") test = Array.new end a = model.selection for object in a test.push object.typename end for object in test puts object end end rc = Sketchup.active_model.set_attribute("TM_area", "test", "false") ; puts "rc = #{rc}" ; tmTest
Thanks Todd
Actualy, I need this to keep track of some add_text objects I create - so that I can run through the 'test' array and delete the objects that I have created, even if the file has been saved and Sketchup restarted. Will this be possible ?
Is this right ?
"rc = Sketchup.active_model.set_attribute("TM_area", "test", "false") ; "
do you save the test array ?As you (and surely many others) can se, I'm not a programmer, just an architect, that have a need for a special function, and tries to create this by looking in others scripts and in this forum
Maybe there should be two groups under Ruby, one for programming ruby/sketchup and one for using plugins ?
JorgensenThanks
No, that doesn't save a test array at all. that saves a key of "test", and it's value" of "false".
If you want to save an array worth of data, and then get it later, here is the code to do that:
def save_array(data) model = Sketchup.active_model dictionary_name = "TM_area" ; i = 1 ; data.each {|value| model.set_attribute(dictionary_name, "var"+i.to_s , value ) ; i+= 1 ; } end ; def get_array() model = Sketchup.active_model any_array = [] ; dictionary_name = "TM_area" ; i = 1 ; while true value = model.get_attribute(dictionary_name, "var"+i.to_s ) ; break if !value any_array.push(value) i += 1 ; end return any_array ; end ; myarray = [] ; myarray.push("This is the first entry") ; myarray.push("Entry #2...") ; myarray.push("3rd and final entry.") ; save_array(myarray) ; myarray = [] ; # reset array to empty myarray = get_array() ; i = 1 ; myarray.each {|value| puts "Value #{i} is #{value}." ; i+=1 ; }
Hi Todd
Thanks for your input - it works well
I have one problem though:
I use the get_array to recive an array (logic)
I then run through this array - witch contains some entityIDs and if an object, with this ID exist, I delete it from the model and from the array. I then save the array again.The problem is, that even if I delete some keys from the Array - so lets say the original array has an length of 10 and I then delete five objects, the length of the array is 5. I then save the array - from i=1 to i=6 - but the old ones from 6-11 still exits in the dictionaryname - how do I delete the var1 - var10 before updating the dictionaryname ?
Jorgensen -
I guess it could be solved via delete_key - but how ?
I have just tried to save
model.set_attribute("TM_area", "objects", data)where data is an array - I can close sketchup and open gain, reload the file and the array can be read again as model.get_attribute("TM_area", "objects")
Works fine - BUT
why the #Β€"#Β€%Β€%) have the entityID for the objects I created change when I reload the file ? now I can't keep track of them anymore
a guite tired
Jorgensen -
I guess this has something to do with it
"The entityID is not persistent between sessions."But how can I then recognise objects when a file is reloaded ?
Jorgensen -
I'm certain there is a delete method to get rid of a dictionary key. Before saving the array, delete all existing keys. It's a brainless (simple) way to do it.
How? Figure it out! Use the Ruby console to experiment. http://download.sketchup.com/sketchuphelp/gsu6_ruby/Docs/Ruby-AttributeDictionary.html#delete_key
You can't use entityID across SketchUp session. Assign them your own ID as a key/value. "Jorg1", "Jorg2", "Jorg_Cabinet", "Jorg_Oil_Platform", etc. Whatever you want to call them. Use some Dictionary name that you expect will be unique in the bog scheme of things. Perhaps a dictionary names like "Jorgensen" or something unique to you / about you. I use "Smustard".
Todd
YES YES YES YES
I found the solutionI add a entity.set_attribute ("TM_area", "TM_ID", "TM_ID " + target.entityID.to_s)
This is kept and can be used to recognise the objects - finally the script can be finshedI won't disturb anymore - I did that quite alot - sorry
Thanks Todd (thanks all)
Jorgensen
Here it is in action. This will be very useful for me when sketching projects with focus on areas
@jorgensen said:
YES YES YES YES
Jorgensen
Be advised that entityID can change when a file is saved and loaded. I hope that isnt a problem for your application.
That should not be a problem, because I'm adding my own attribute:
entity.set_attribute ("TM_area", "TM_ID", "TM_ID " + target.entityID.to_s)that I use to keep track of objects.
Jorgensen
