    πŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    Texture Question
    10 Posts 6 Posters 507 Views 6 Watching
      dylan
      Im no expert in creating seamless textures. I have recently worked out how to create decent seamless textures with straight edge items such as bricks and timber siding, but I cannot get this image to work.
      Is it possible to create a good seamless texture from this style of timber board?
      http://dmdarchitecture.co.uk/
        tomsdesk
        Dylan, either of these work for you (I used the seamless tile maker in PSP after making the image square)?
        2.5D Trees & Shrubs!
          Stu
          Dylan the short answer is no. Those noticable twists in the boards are going to be repeated ad infinitum with a very messy result unless you are texturing no more than a square metre or so.
          πŸ˜„
          http://www.landesign.com.au
            tomsdesk
            Bruce, had done that already as an after thought...so excellent idea :`) Here's the result: a little better, I think.z3-larch%20waney%20edge.jpg
            And of course, Stu's right about the repeating wavy...though better than could be, I think.tn_zskippy-larch%20waney%20edge.jpg
              Jackson
              With textures like this- long and irregular boards for example, the easiest and best way is to just get a much longer photo to start with. Otherwise as stated above the results will be very poor unless you're a Photoshop genius which I am definitely not.
              Here's a similar texture I made from a nice long fence near my flat, although the boards are much straighter than the ones in your texture. It still has a noticable repeat pattern when used horizontally (the actual fence is vertical boards), but it'd be fairly easy to make it tile better horizontally.
              Great job Tom BTW.
              Jackson
                Free wood seamless textures πŸ˜‰
                  Jackson
                  Pilou,
                  I've got that program, but it's very limited both in what you can produce and the quality... unfortunately the textures almost never look photorealistic. I don't think it's capable of producing rough edged sawn fencing like Dylans, although maybe I just didn't mess around with it enough.
                  Jackson
                    dylan
                    Thanks guys for all your help. πŸ‘
                    I will see how it looks when I finish the model.
                      tomsdesk
                      Bruce, this is beautiful...nice work!
                        dylan
                        Thanks Bruce, this will be perfect for my needs πŸ‘
