    Animation
    17 Posts 10 Posters 1.8k Views 10 Watching
    • spenceS Offline
      spence
      Here is one of my latest animations. Now, I really would love to spend more time with this, I just thought I would quickly export a simple fly around. One thing, The video starts out with some weird problem, the video I uploaded does not do this, only after uploading to youtube does it look weird in the begging. If anyone knows what is going on or can help, would be great. Here it is the video, take looksee.
      indoor waterpark
      Spence
        You Tube somehow compresses the videos (both file size wize and pixelwise) and it must be due to that these compressions often screw things up.
          mateo soletic
          Apart from the wierd problem at the beggining what I dislike is the way that the picture holds or staggers in between pages.I also havent found a way to avoid that comletelly. If anyone has an answer how to get a continuous flow like in this case when cam is circling the object by 360 degrees I would love to hear about it.
          [Concept Illustrations](http://concept-illustrations.com/)
          • spenceS Offline
            spence
            I'm with you 100% Meteo. The only way I know of is to cut those parts out in video editing software and replace with transitions, fades and so on, but that still does not make for a nice fly around. This problem in between pages does not exist in programs like Vue (there are no pages), I have an example of spinning around an object here. I really, really would love so badly to see Sketchup come up with a better animation system. I think its important to be able to show designs this way.
            Spence
            • O Offline
              otb designworks
              I completely agree. Upgrading the animation aspect of SU is badly needed and would be highly appreciated by at least me.
              Cheers, Chuck
              OTB Designworks is on Youtube
                mateo soletic
                I agree with both, I think that SU is a perfect application in the coceptual stages of design and with it the animation could be a
                perfect tool in massing and sun and shadow study.I think they should adopt a different system than the one they have at the moment with pages for animation.
                Pages can remain as a parallel system of presentation but they should adopt another one
                like the one that 3DS MAX or VUE have.
                  Scotty T
                  What I have had to do is create 4 to 6 different animated scene perspectives in SU and then export the animations to post editing and create a transition between the perspective scenes to cut out the knee-jerk. So instead of attempting a full 360 just create a handful of sweeps around different parameters of the structure and post edit for smooth transitions and this will give you more creative flow once you get the big picture.
                  • marked001M Offline
                    marked001
                    has anyone use the FlightPathTool.rb? i've only used it once b/c i dont do animations too often...but it worked pretty nicely after some trial and error... you basically draw the path of the camera with arcs...and set a target for the camera to look at.. and you can do it in sections.. so you can have different targets....it creates the pages for you and you export just like any other sketchup animation..and no need to create transitions, etc.. i've got an example, but its not uploaded and it probably wont sell the tool very well πŸ˜‰ great job, though spence..
                    http://www.revision21vis.com
                    instagram: revi21on
                      todamgood4U
                      A) I agree, the animation needs serious help. It sure would be nice to have more control through each point. My biggest problem is, when going from point A to point and then to point C, the variation in speed if the points are at different lengths. I know I can export the 2 seperately, but it sure would be nice if I could specify transition time for each one instead of global.
                      B) Mateo, your new avitar makes you look like Simon Cowell...or are you really Simon Cowell and you are trying to look like Mateo....hmmmm.
                        sepo
                        Has anyone tried this
                        Page not found – Villkor pΓ₯ casinon | Hitta ditt nya favoritcasino
                        (www.ohyeahcad.com)
                        • tinanneT Offline
                          tinanne
                          (www.ohyeahcad.com)
                          can you make the "path" invisible so you don't see it in your animation?
                          Executive Director : American Society of Architectural Illustrators
                          AIP 30 Competition opens soon. ASAI.org
                          Architectural Rendering
                            sepo
                            Tinanne
                            In all honesty I don't know but I shall find it out for you
                              marked001
                              so does this just animate 'objects'...or can it animate the camera as well?
                              instagram: revi21on
                                sepo
                                Tinanne... As it is weekend could not talk to Dave to see if it is possible. Will keep you posted.
                                Mark ...Yes you can animate object or camera.
                                  dylan
                                  I was considering trying this out, but what put me off was the path showing. I contacted the makers via their forums and was told you can hide it.
                                  http://dmdarchitecture.co.uk/
                                    marked001
                                    you can probably just put it on a layer and hide it?
                                    instagram: revi21on
                                      sepo
                                      Yep...that is the way to do it.
